85 Cranking Issue
Old Jul 21, 2013 | 06:45 PM
IrishHooligan's Avatar
85 Cranking Issue
Have a 85 Toyo with a 22RE. It will run fine for day or two then becomes hard to crank. When you try to crank it all it will do is click for ten to fifteen min, then crank with out a problem.
Prev. Owner changed starter, battery, all cables and switch
Anyone able to help?
Old Jul 21, 2013 | 07:48 PM
Chickenman's Avatar
Sounds like solenoid contacts are worn. Replace them and you're golden.
Old Jul 21, 2013 | 08:58 PM
i will try that thank you
Old Jul 22, 2013 | 01:22 PM
toyota like a chevy solenoid mounted on starter. new starter new solenoid and contacts. took it and got checked starter and components still good
Old Aug 2, 2013 | 09:13 PM
Negative07's Avatar
I donno if it was the same problem I had with my 4runner when it wouldn't start and made that clicking sound i think it was a relay clicking. It ended up being the leads on the negative battery connection that were corroded, cleaned them and she start right up. Also it wouldn't hurt to check your starter relay and check your starting related connections or conectors. Hope that helped.
Old Aug 4, 2013 | 09:09 AM
jon6.0's Avatar
I just had to bang on my starter solenoid last night to get mine to turn over. I thought it was a dead battery, but after charging it all night it just clicked. So I tried the bang on the solenoid trick and she fired right up.
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
redneck17
Jul 17, 2015 07:44 PM
Poncho0206
Jul 10, 2015 06:21 PM
