Aftermarket Center Console???
Old Jul 29, 2010 | 05:42 PM
1st_gen_runner's Avatar
I have an 85 4runner SR5. It has the back seat heater, so my center console is only about an inch deep. Does anybody know of any aftermarket center consoles, locking or not, that I could replace it with? I will be doing away with the heater in the center console, so that won't be an issue.
Thanks
Old Jul 30, 2010 | 07:03 PM
myyota's Avatar
Your just going to have to look around to see what you can find that you like and that will fit. Im in the same position right now, i just can`t find anything that i like or that will fit in the space between the seats.
Old Jul 30, 2010 | 07:09 PM
1981 yota's Avatar
ammo cans work for great center consels
Old Jul 30, 2010 | 07:13 PM
4Crawler's Avatar
I put a Tuffy Security console in mine:
They have a smaller 6.5" wide unit that fits in between the seats or I went with the full 8" wide unit and moved the seats out a little bit. Sits a little far back right now, with the rear t-case shifter in the way. Will move it forward once I finish up my triple stick shifter that is moved forward 6"-7".
Old Jul 30, 2010 | 08:43 PM
Where did you get the Tuffy unit? I would be interested in the 6.5" inch one so I wouldn't have to move the seats, would you happen to know the part number or anything so I could look it up specifically? Thanks for your help!
Old Jul 30, 2010 | 08:44 PM
Also, how exactly would it bolt in to the vehicle? Do you need to make mounts or will it bolt to the existing holes or what?
Old Jul 30, 2010 | 08:45 PM
4Crawler's Avatar
I got mine from JC Whitney some years ago. Don't recall the p/n off hand, should be able to find it below:
- http://www.tuffyproducts.com/c-4-consoles.aspx
I just drilled mating holes in the bottom of the console to line up with the 3 factory console mounting bracket holes.
Old Jul 30, 2010 | 09:47 PM
Think this one would fit?
http://www.tuffyproducts.com/p-94-02...6-12-wide.aspx
Old Jul 30, 2010 | 10:05 PM
BerHntr's Avatar
I just got one out of a 95 4runner and put it in.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
mct75
Aug 22, 2016 01:24 PM
icentropy
Sep 10, 2015 05:03 AM
Highlander Giant
Sep 8, 2015 06:46 PM
justdifferentials
Sep 5, 2015 06:52 PM
