85 wont run, engine troubles
Old Jun 12, 2006 | 06:40 AM
thebeast8888's Avatar
im goin crazy
ok so my 85 22re is ill i dont kno wtf happened but the timing isnt advancing when i rev the engine, and if i rev it fast it just dies, it sometimes backfires into the airbox, it seems like it i rev the engine the timing retards toward top dead center, i dont kno what is goin on please help me
ive been lookin for answers on the ttora board for a while now but i thought i would post here aswell
if you feel like reading my thread there heres the link it has all the info
http://www.ttora.com/forum/showthread.php?t=34867
also dont kno if this is connected or not but i suspect it is, my steering feels like its loosing power when i turn about half way. feels liek trying to drive without steering fluid
Old Jun 12, 2006 | 08:45 PM
im so glad eveyone is helping me
Old Jun 12, 2006 | 09:05 PM
84sr5yoty's Avatar
Probably because that's a very odd problem. The computer controls the timing.
Have you checked the advance weights to make sure they're not stuck (if that distributor even has advance weights, I don't know)? Mine were almost welded in the closed position on my 59 Pontiac.
Have you checked computer codes yet?
Another possibility is to test out the signal generator. 140-180 ohms. Take the reading with the motor at normal operating temperature, since that's when they show their faults. Faulty ones usually test fine with a cold motor.
Old Jun 13, 2006 | 08:26 PM
checked all that and its good
do you think putting a grenade in my cylinder would help?
Old Jun 13, 2006 | 08:42 PM
wrenchmonster's Avatar
Assuming you've checked all the obvious simple stuff, pull out the distributor and inspect the gears. Inspect for sloppy or cracked distributor shaft. Only seen it a handful of times in many years, but it can happen. Good luck.
Old Jun 14, 2006 | 02:27 PM
im thinking its either clogged injectors, or a short
Old Jun 15, 2006 | 05:17 AM
azredliner's Avatar
Cut the aggravation and put a Weber carb on it. I did it to mine and I didn't lose any power, in fact it has more torque.
Old Jun 17, 2006 | 11:25 PM
um its efi.....
Old Jun 18, 2006 | 01:46 PM
spirtlanimilbus's Avatar
for off road use id lean towards efi over a weber carb. ever been in a mudpit or on a rough trail and had the engine die because the float pins were knocked out of whack? on a stock 22r carbed truck id stick witrh the aisin carb instead of a weber but a holley 2300 350 cfm carb would be my choice... a weber 32/36 flows the same as stock or less a weber 38/38 would be the way to go with a weber. if you understand efi and how it works your alot better off sticking to it. if your tps is off it could cause this issue that and the dizzy...
Jmiller1023
23
Aug 6, 2015 07:03 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
ra72
Jun 16, 2015 11:10 AM
