85 Truck Clearance for the rear driveshaft
Old Oct 22, 2014 | 04:49 AM
josephpatrickgray's Avatar
I know you can run a high pinion for the front diff. How can you gain some driveshaft clearance for the rear diff and driveshaft and diff?
Old Oct 22, 2014 | 05:34 AM
nothingbetter's Avatar
cut your spring perches and rotate your housing, weld back on. Be careful of your pinion angle.
Old Oct 22, 2014 | 05:44 AM
dropzone's Avatar
Fossilized
taller tires help too.
Old Oct 22, 2014 | 05:45 AM
I am running 37s. Hopefully rotating will do the trick.
Old Oct 22, 2014 | 06:31 AM
What is the best way to determine the correct pinion angle?
Old Oct 22, 2014 | 07:48 AM
JasonYota's Avatar
Angle finder tool.
Old Oct 28, 2014 | 07:20 PM
osv's Avatar
osv
the 4runner i got had a rotated rear end, and something kept vibrating on deceleration.
i ended up having to get a cv joint put in the front of the rear driveshaft, similar to how the front driveshaft is set up.
search the archives for info.
Old Oct 28, 2014 | 07:29 PM
muddpigg's Avatar
I had to switch to a CV rear shaft, clearance the "horse collar," and rotate pinion angle. Short wheelbase and dual cases. Used a piece of 10" pipe to arch where I clearanced the horse collar. Looks really good till you see my booger welds
Would be helpful if you gave specs and what the clearance problem is.
Old Oct 28, 2014 | 07:34 PM
in order to "test run" the pinion angle, you can also buy angled shims to put between the leaf spring and the spring perch. I wouldn't use it is a permanent fix but its a good way to double check that you have chosen the right angle before you do all the work cutting and welding.
Old Oct 30, 2014 | 02:24 PM
I have double transfer cases and a cv driveshaft. Three inch trail gear lift with five in h schackles.
Old Oct 30, 2014 | 03:55 PM
muddpigg's Avatar
I used string and an angle finder to figure out pinion angle. Then subtracted 2* to allow for spring wrap. Used angle finders to cut and weld on new spring perches.
To do it again I'd tack on spring perches then recheck angle of pinion with weight of truck on it.
The angle I had to rotate the rear pinion was more than was recommended with shims for a road driven vehicle. 70mph is about my top speed much over and I notice drive line vibrations depending on what's loaded in truck.
I also made re-enforcement plates to go in front and rear of spring perches as I'd seen post of were the commonly sold style will collapse.
Think 4crawler had a good link to a site that explained the different types of drive lines. Searched for you but couldn't locate.
slacker
13
Sep 6, 2015 06:14 AM
Valvoman
Jun 28, 2015 02:45 PM
cchinny
Jun 25, 2015 08:11 PM
TheManOutside
Jun 18, 2015 03:32 PM
