85 Pickup Fresh Rebuild NO Start Help PLZ
Old Jun 13, 2011 | 12:39 PM
Drock970's Avatar
Nope i see no gas when I look down the carb or in the window. Bad fuel pump?
Old Jun 13, 2011 | 12:40 PM
Drock970's Avatar
Here are those photos
http://photobucket.com/drock970carb
Old Jun 13, 2011 | 12:54 PM
sebastianholmes's Avatar
to make life easy. next time use it IMG code
Old Jun 13, 2011 | 12:55 PM
whats the big open thing cleary visible in all 3 pics? something tells me that cant be right and at least needs a cap
Old Jun 13, 2011 | 01:06 PM
  #25
stepside trd's Avatar
You need to cap off those two wide open vacuum ports, otherwise, even if you do get it to run, it'll never run smoothly. That is prob. why you think your timing is off. Second, unplug the fuel inlet hose going into your carb, and place it into a catch cont. have someone crank the motor and see if your pump is working and it will also tell you if your fuel filter is clogged. If all's good, then you have just narrowed down your prob. to your carb. Reset you dist. and make sure it is on your intake stroke.
Old Jun 13, 2011 | 01:25 PM
  #26
dropzone's Avatar
Fossilized
Originally Posted by Drock970
X2 on using the [img] code.
Drock970:
also I merged your other thread from the build section, it wasn't a build thread. Please don't create duplicate threads on the same subject in the future.
Old Jun 13, 2011 | 04:17 PM
  #27
Drock970's Avatar
Hey man thanks for blowing up my pics for me. The ports that are open are vacuum lines to the intake filter on the carb. Just removed the airfilter cover to get pics. I check and see if I have the correct fuel pressure and ill let you guys know.
Crazychris1871
Jun 27, 2016 10:38 AM
red88toy
11
Aug 3, 2015 07:47 PM
bigblue82
10
Jul 6, 2015 08:27 AM
shadowbirdie
Jun 24, 2015 03:54 PM
duckhead
3.4 Swaps
7
Jun 18, 2015 06:54 AM
