Nope i see no gas when I look down the carb or in the window. Bad fuel pump?
whats the big open thing cleary visible in all 3 pics? something tells me that cant be right and at least needs a cap
You need to cap off those two wide open vacuum ports, otherwise, even if you do get it to run, it'll never run smoothly. That is prob. why you think your timing is off. Second, unplug the fuel inlet hose going into your carb, and place it into a catch cont. have someone crank the motor and see if your pump is working and it will also tell you if your fuel filter is clogged. If all's good, then you have just narrowed down your prob. to your carb. Reset you dist. and make sure it is on your intake stroke.
Fossilized
dropzone
Fossilized
close
- Join DateOct 2005
- LocationPNW
iTrader Positive Feedback100
iTrader Feedback Score(6)
Liked:456 Times in 301 Posts
Quote:
X2 on using the [img] code.Originally Posted by sebastianholmes
to make life easy. next time use it IMG codeDrock970:
also I merged your other thread from the build section, it wasn't a build thread. Please don't create duplicate threads on the same subject in the future.
Hey man thanks for blowing up my pics for me. The ports that are open are vacuum lines to the intake filter on the carb. Just removed the airfilter cover to get pics. I check and see if I have the correct fuel pressure and ill let you guys know.
