85 p/u 22re HARD to start HOT or COLD!
Old Nov 23, 2012 | 05:57 PM
JPond53's Avatar
Question 85 p/u 22re HARD to start HOT or COLD!
I recently got an 85 pickup SR5 4x4 22re project...My buddy and I have been working on it and so far we have changed the timing chain, guides, and tensioner, the o2 sensor, checked the valve clearances which are all good, all pistons have compression between 135-140, jumped the fuel pump relay to make sure the fuel pump works and it does, went up and down a gear on the distributor and that didn't help. One thing that I have noticed is that when we check the timing it runs like complete crap when set to 5* and thats about as retarded as we can get it so I run it advanced about 1/2-1/4 inch from the 12* so I can drive the thing without it being completely gutless. I've messed with the air/fuel screw countless times and the engine at idle seems to have a miss every so often. When revved up between 2000-3000 it runs fine. and runs fine with normal driving........does ANYONE have an idea of what could be going on? PLEASE HELP! I am out of ideas and have no idea what to do....Thanks!
Old Nov 23, 2012 | 07:33 PM
rokblok's Avatar
The occasional miss at idle is prob a lean miss. Pretty normal fo high altitude vehicles, although I'm not sure at what altitude Reno is.
Old Nov 23, 2012 | 08:23 PM
JPond53's Avatar
Reno is at about 4500ft...would that effect me that much? Is there a way to get that lean miss to be gone since I think it's one of the factors to why I'm failing smog. Any ideas for the starting issue?
Old Nov 24, 2012 | 04:50 PM
JPond53's Avatar
Does ANYONE have a clue? Im sure there is somebody out there that had the same problem or almost the same....
Old Nov 24, 2012 | 05:04 PM
Hotwlz's Avatar
I ran into the same problem today in reno I just read that the idle mix screw for an 85 is supposed to be backed out 4 to 4.5 turns we had the same problem with the miss and after the correct adjustment its smooth as silk and it starts much better have you changed the accelerator pump diaphragm mine had a small hole in it when i bought it and I had to crank and crank or give it a shot of starting fluid and now it starts like like an EFI.
Old Nov 24, 2012 | 05:15 PM
JPond53's Avatar
Not too sure how much my screw is backed out I would have to go check...where is the accelerator pump diaphragm? Like you were saying how yours cranks and cranks thats exactly how mine is...I have to crank it for like 10 seconds till it starts firing and then a couple more seconds till its fully running.
Old Nov 24, 2012 | 05:19 PM
Hotwlz's Avatar
Same side as the adjustment screw lower right held in with 4 phillips screws really easy to change napa on glendale has them in stock for like 5 bucks
Old Nov 24, 2012 | 05:40 PM
JPond53's Avatar
Oh awesome that's a cheap fix! Can you possibly take a picture of it and email it to me?
Old Nov 24, 2012 | 05:49 PM
Hotwlz's Avatar
Yeah what's your email
Old Nov 24, 2012 | 05:54 PM
JPond53's Avatar
James.pond53@gmail.com
Old Nov 24, 2012 | 06:12 PM
JPond53's Avatar
Does this apply to the fuel injected 22re? I see yours has a carb...
Old Nov 24, 2012 | 10:01 PM
rokblok's Avatar
Fuel injected(22RE) does not have an accelerator pump. And what screw are you turning to adjust mixture? I didn't catch the RE earlier, so in light of that, have you tested your O2 sensor? Fuel injected engines are, for the most part, ECU controlled mixture via changing the amount of fuel going in through the injectors. The O2 sensor "sniffs" the exhaust and tells the ECU when it's running to rich or lean, and the ECU adjust accordingly. Now someone else may be able to comment on the 22RE specific controls... My comments are general fuel injection guidelines...
Old Nov 25, 2012 | 06:19 AM
JPond53's Avatar
Theres a screw on the right side of the engine (as you're looking at it) right below the throttle cable and dash pot. I changed my o2 sensor and since then have been getting a huge gain in mpg's which I think will help my smog issue. But now i'm battling this starting issue. Maybe my injectors are bad??? I'm a little baffled at this point...
Old Nov 25, 2012 | 09:00 AM
203Cree's Avatar
Timing should be at 8*. Check your temp sender and your cold start injector. Something to think about.
Old Nov 25, 2012 | 10:40 AM
Crtzlow's Avatar
Any trouble codes flashing?
Old Nov 25, 2012 | 03:00 PM
JPond53's Avatar
@203cree will check those out and see if that works.
@Crtzlow no trouble codes at all...I read on marlin crawler to plug off my egr and see if that works? I also just jumped the fuel relay again and it started right up..I notice that when I don't jump it and turn the key I cant hear the fuel pump buzzing but when I jump it I do..whats tat mean?
Old Nov 25, 2012 | 06:17 PM
203Cree's Avatar
Means your fuel pump relay is weak.
Old Nov 25, 2012 | 07:31 PM
rokblok's Avatar
Also known as COR. Circuit Open Relay
Old Nov 25, 2012 | 08:08 PM
JPond53's Avatar
Okay awesome! I'm finally getting somewhere So is there a way to test the COR or get a new one? And if so how? Thanks!
Old Nov 26, 2012 | 03:40 AM
Crtzlow's Avatar
My 85 22RE fuel pump does not come on until you turn the key to start. The fuel pump is turned on by the air flow meter. It has a baffle (compensation plate) in it that engine vacuum pulls and turns the fuel pump on. FSM chapter 5, EFI system, page FI56 shows opertion and checks.
Fuel pump circuit attached:
Attached Thumbnails 85 p/u 22re HARD to start HOT or COLD!-0001.jpg
