85 ext.cab 2 piece drive shaft help
ok converting my 85 std. cab over to the 85 ext. cab but i noticed that the ext. has two driveshafts in the rear with a bearing. What im looking for is what you guys are running on your ext.cab rigs. one or two piece rear shaft ? what kinda joints? how would the angles be?
1985 yota ext.cab 5" tg springs 2" body lift one transfer case
Mine from factoryis a two piece with the carrier bearing in the middle of the two shaft sections. But I am changing mine to a one piece. From t-case to diff.
I have an '84 extended cab.
Thanks for the drivehsaft info !!
oh and trust me i search the crap out of the junk yard around here . Its like the workers pick them clean before the trucks even hit the yard .I swear toyota trucks are the hottest thing in the wrecking yard .
And it sounds like I need to visit your junkyard... I don't care if its in Va...
So the donor truck must be the same body style? Like 84-88 only, the 89-94 body style wouldn't interchange?
And I have yet to find a factory one piece shaft in an extended cab truck in my local yards... Several two pieces, so I snagged a front DC shaft that I was gonna get extended. But if I can find a factory one piece shaft...l
