85 ext.cab 2 piece drive shaft help
Old Mar 20, 2012 | 02:58 PM
Night-rider123's Avatar
Or actually from weld to weld on shaft will be easier.
Old Mar 20, 2012 | 03:05 PM
Nvm that idea i totally forgot that you wouldn't have a slip joint so yeah you gotta find 4wd shaft.
Old Mar 20, 2012 | 03:27 PM
rokblok's Avatar
All driveshafts have to have a slip joint if the differential moves. I am guessing that the 2wd shaft slip joint is on the tailshaft. I don't know anything about 2wd Toys...
Old Mar 20, 2012 | 03:57 PM
Yeah they are
Old Mar 20, 2012 | 04:07 PM
  #25
rokblok's Avatar
I guess I will continue attempting to find the ever elusive one piece factory shaft until I get the funds for DC extended front shaft... Whichever comes first...
Old Mar 20, 2012 | 04:43 PM
  #26
85TurboRunner's Avatar
Hmm I've had 2 extra cabs and both had the one piece shaft. One an '86 one an '87.
I'm running 4" of lift in the rear of my truck plus 6" shackles and the shaft is fine, no worries of it coming apart at all.
If you can't find one just take a standard cab or 4runner shaft to your local driveline shop and have them lengthen it.
Old Mar 21, 2012 | 10:08 AM
  #27
thefishguy77's Avatar
So if what I just read is correct they stopped using the 2 piece after 85. My last 85 xtra cab had a 2 piece and was almost maxed out with a 4" lift. Still trying to find another 85 but excited to hear that 86 has a solid drive shaft.
Thanks for all the great posts
Old Mar 21, 2012 | 01:01 PM
  #28
No the 2 piece shaft was used through the 90's and maybe even later.
Some trucks just had a one piece shaft. Not sure why some did and some didn't.
A2theK
Jan 10, 2016 10:18 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Poncho0206
Jul 10, 2015 06:21 PM
crashburnoveride
Jul 10, 2015 06:39 AM
