85 4runner front axle rubuild help
Old Jul 5, 2009 | 02:17 PM
johnnyjay's Avatar
O.k. Just got done with the rear and it went smooth. Thanks for all advice I got from everyone. Now I want to tackle the front axle, the previous owner put a seal rebuild kit on the driver side and I have another one for the passenger side. Also it is leeking arould the 3rd member seal. So here is my questions(1) is there any pics or write up on a solid front axle that would show the tear down and rebuild process and (2) will I have to pull the driver side out to replace the 3rd member gasket like I did in the rear. This is the last thing I need to get done to get her on the road so any help would be appericiated. Thanks John.
Old Jul 5, 2009 | 03:29 PM
slacker's Avatar
I keep this bookmarked
85 front axle
and yes , you will have to pull the other axle to remove the 3rd
Old Jul 5, 2009 | 03:47 PM
waskillywabbit's Avatar
Our Factory Service Manual thread has one for the 85 model. Shows it all.
Old Jul 5, 2009 | 03:52 PM
BLKNBLU's Avatar
Here are a couple to pick through.
http://www.4x4wire.com/toyota/mainte...nd/solid_axle/
https://www.yotatech.com/forums/f115...ctures-180536/
Old Jul 5, 2009 | 04:07 PM
johnnyjay's Avatar
O.K. there is a little more than the rear axle. Is this somehing that I can do or will I need to take it to a shop? Also it looked like there was some special tools I will need. I have the axle on stands and the tires off. Thanks John.
Old Jul 5, 2009 | 04:37 PM
johnnyjay's Avatar
O.K. I take it all back (for now)
Thanks for the links, I think I got this thing whipped. Iam going to start one afternoon this week. Its just the shims part that has me worried. But If I count the old ones then just replace it with new I should be fine. Thanks everyone, John.
Old Jul 5, 2009 | 04:57 PM
BLKNBLU's Avatar
Yeah, you'll be good to go. I muddled through mine without really knowing what I was doing. You don't really need anything special other than the 54mm socket, which you ought to have anyways if you own a Toy.
http://www.marlincrawler.com/hardwar...ls/54mm-socket
I bought one of these and it's worth it's weight in gold in terms of time & frustration savings.
http://www.marlincrawler.com/hardwar...ap-ring-pliers
And this looks handy, but I've managed to live without one so far.
http://www.marlincrawler.com/hardwar...seal-installer
Otherwise general tools and a good torque wrench.
Old Jul 5, 2009 | 05:07 PM
slacker's Avatar
you dont have to "replace" the shims .. .. just "mark" them and keep them in order ...
heres a brief thread on my axle build .
http://toyotatrekker.proboards.com/i...play&thread=63
hope that helps.
Old Jul 5, 2009 | 05:20 PM
Yep, no need to replace the shims. Just reuse them but in the same place that you removed them.
Old Jul 8, 2009 | 04:37 PM
johnnyjay's Avatar
O.K. just got it all undone and when I was cleaning the 3rd member it was leaking around the yoke. So is the seal around the yoke shot or was the weith of the diff causing it?
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
lledwod
Aug 30, 2016 01:03 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
