4x4 Not Working!!
Old Apr 6, 2015 | 05:38 PM
theduck21's Avatar
4x4 Not Working!!
Needing again guys. Bought this 85 sr5 4x4 xtra cab stock straight axle pickup with AUTOMATIC locking hubs that sat for 3 years. Got it running and driving down the road got home and wanted to check and make sure the 4wd worked. Got all 4 tires off the ground, shifted into 4 high in first gear, back tire spun but front did nothing. Shifted into 4 low, back tire spun slow but again, front did nothing. The front shaft was spinning. After I shut it off I took the plug off the front diff to make sure it actually had gears in it and it did. There are no vacuum lines going to it, just a nipple on the top passenger side of the differential. PO said the hubs were rebuilt before it was parked. Any clues?
Old Apr 6, 2015 | 05:43 PM
JasonYota's Avatar
Uh the auto hubs… take them off and see if everything moves freely inside. That's where I'd start
Old Apr 11, 2015 | 08:45 AM
theduck21's Avatar
I think I'm just going to upgrade to manual warn hubs
Old Apr 11, 2015 | 08:49 AM
theduck21's Avatar
After I took the hubs off they looked terrible grease was caked up and metal shavings everywhere but the axle shafts were spinning. Everyone says to just go to manuals so that's my plan
Old Apr 11, 2015 | 09:41 AM
JasonYota's Avatar
Metal shavings are not good. Look here for manual hubs for sale.
Old Apr 15, 2015 | 09:27 AM
theduck21's Avatar
So with the hubs on nothing moves but the hubs off the axle shafts move fine. So that is definitely locking hubs right?
Old Apr 15, 2015 | 12:16 PM
JasonYota's Avatar
Not quite sure what your asking
Old Apr 19, 2015 | 06:53 AM
theduck21's Avatar
With the locking hubs on, in 4wd the front driveshaft is spinning but not the tires or hub. When I take the locking hub off the front axles turn fine. So that's definitely hubs?
Old Apr 20, 2015 | 10:00 AM
JasonYota's Avatar
Yes that's right
Old Apr 23, 2015 | 08:34 PM
cabot's Avatar
I'm retarded and late with the info I posted
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
