4:88 gears with 35 "
Old Dec 10, 2012 | 12:51 PM
Staceman1's Avatar
FWIW:
I have 35's and 4.88's. I bought the complete 4.88 diffs from a 1994 Pickup at a junk yard. $275 for both complete diffs. I saved so much that the extra $$$ went towards a lock-rite locker for the front, LSD for the rear. It's my daily driver.. My speedo is dead on with the GPS, Power and 5th gear are as if I had tiny stock 29" tires with 4.10's.
Old Dec 10, 2012 | 01:22 PM
highonpottery's Avatar
Originally Posted by bob200587
New gear sets aren't very expensive. My thinking is that it is worth it to spend $75 extra to get a new set vs. a used set that you don't have any idea how they've been treated or how worn they are.
If I can have a new product for just a little more than the same product used, I'm going with new pretty much every time.
where the heck are YOU buying gears at? i'd love a $75 set of gears.
every gear set i've ever looked at was around the $150-200 mark, plus the $100-150 for an install kit, then you most likely gotta pay a couple hundred for someone to install it...and multiply by 2 since you gotta do the front also.
Old Dec 10, 2012 | 02:18 PM
junkpile's Avatar
I have 22r 35s, and 4.88s in my 84 and it goes great in 5th. As a matter of fact I ran 35s for a while with 410s and it wasn't too bad. Lots of folks like 5.29s but that's starting to get on the weak side in my opinion. If you can't run 35s with 4.88s its probably time to freshen up your motor anyway. Just my opinion though
Old Dec 10, 2012 | 02:40 PM
bryy's Avatar
He said 75 extra not total.
Old Dec 14, 2012 | 12:57 PM
  #25
bryy's Avatar
Could not agree with you any more, I know this is an old thread but after the holidays I am looking to do a gear switch and want to shed some light on all the research I have done.
How many have drove a toyota 22r or 22re with stock 4.10's and 31' tires, I have and thats where I started my research. If you do the math which gets you with in reason close your mph at 3000 rpm's is 79MPH..I felt the truck had plenty power for what it was and I regularly used 5th gear in town with no problem
Then the lift came and 35's happened with still 4.10's and I daily drove that for a year.(could be worse but was not the best)
Do that same math again :3000 rpm of the engine using a W56-a 5th gear ratio gives you
4.88-75MPH
5.29-69MPH
So running 35's and 4.88 would be a lower gear then running 31's and 4.10 and when accounting tire weights and dual cases im hoping the truck feels like it did with 31's and 4.10
all information was got using
http://www.marlincrawler.com/java/getspd_calc.html
Old Dec 14, 2012 | 03:40 PM
  #26
rbmoomba's Avatar
The width and weight if the tires definitely has an impact. I had 37'x13.5's on 4.10s with little problems (only on overpasses). Then went to 35x15.5 tsl's and had to regear. I went with 4.88s as I'm on the highway a lot. Also dual cased but that's irrelevant on the highway. Good luck. I bought factory v6 3rds with factory 4.88s.
Old Dec 14, 2012 | 03:56 PM
  #27
bryy's Avatar
I only said dual cases because that's just creating a little more drag. I will agree the width plays a huge role . Running proper psi for the road plays a part too
Old Dec 16, 2012 | 04:23 PM
  #28
jaredvrose's Avatar
Originally Posted by rokblok
You prob have like 4.10s or 4.30s(which I think came in 3rd gen trucks). You could maybe find a set of factory 4.88s which would help your giddy up. I got three rear factory 4.88 3rd members for my '84(solid axle front) for like $100 bucks from my local Pullapart. I left the front IFS diffs in all of them since I don't have IFS....
Factory IFS 4.88s came in 2nd gen 4runners with factory 31" tires and tow package. Code on door tag is G144 for 4.88. There is a kicker though... You can't use any other gear sets with these housings. It's a thin ring gear since they offset the pinion to accomplish the ratio. Or something like that....
I presume that the Runner in your avatar isn't the one we are referring to? Cause I'm pretty sure that's a 90-95.5 body.
No i now have an 89 22re auto 4x4 and this is my question: i meant to get back sooner but would having what i think is either 3:90 or 4:10 gears be hard to accelerate at take off with my auto tranny and 33" bighorn tires?i can hardly keep it at 50mph without it dropping into lower gear?any more input is greatly appreciated
Old Dec 16, 2012 | 06:35 PM
  #29
rokblok's Avatar
You prob have 4.10s and I think it would be a slug to drive with stock 22RE, auto trans and 33s... 4.88s would put you back close to stock factory gearing as if you had 28-29" tires. If you go 35s, 5.29s keep you close.
Old Dec 16, 2012 | 06:51 PM
  #30
jaredvrose's Avatar
Yeah i cant pull out in traffic whatsoever without having someone tailgate me.i cant spin the tires even on the softest ground it just creeps slowly.i head from research that 4:56 would be better for me on the highway.i have alot of hills in florida but i dont mind dropping to 3rd gear to climb it.as long as i can go 70mph easily in 5th down the road and get back my mpg im good.im getting like 13 now!! Also im throwing a code 25 and 43 since i got the truck whick from what ive read it looks to be the o2 sensor.any possible waY this could be a big factor?
Old Dec 16, 2012 | 07:03 PM
  #31
rokblok's Avatar
O2 sensor may affect a little bit of how much power it seems to have, but it shouldn't be detrimental like you describe.
Where in Fla do you have hills? Central or panhandle is all I can think of, and I'm in Fla weekly at least. My truck can take those hills at 75-80 all day long.
Old Dec 16, 2012 | 07:13 PM
  #32
rokblok's Avatar
Sorry, to answer your question, yes, 4.56 would give you a bit longer legs( lower RPM for cruising) but with an auto, I believe you would want the 4.88s since they are pretty long-legged by nature. Auto trannys bring the cruise RPM down lower than a 5spd would.
If you had your auto equipped truck with 33s, and my 5spd truck with 33s, both with 4.88 gearing, your RPM would be lower than mine at highway speeds.
Old Dec 16, 2012 | 07:34 PM
  #33
suncomb1's Avatar
You should run 5:29's with 35" tires. 4.88's are good up 33" and will work okay with 31" tires. Years ago there were some good tech articles in magazines about changing gears and nobody here talks about breakage. When you go from 4:10 to 4:56 gears you reduce the gear set strength about 15%, when you go to 4:88 you reduce the gear set strength about 20% and when you go to 5:29 gears you reduce the gear set strength 40-45%. In addition, stock Toyota axles were not designed for 35" and up tires period so it is good that most stock Toyota motors do not produce a lot of horse power because if they did we would have broken gear sets and axles all over the place. If you want to go big then at least purchase high strength / quality axles and gear sets but that are not cheap.
Old Dec 16, 2012 | 07:39 PM
  #34
rokblok's Avatar
I beg to differ. They may not have been "designed" for 35" tires, but they are over-engineered in my opinion, and I've seen many a higher powered Yota running 35s and larger for many years personally. And I've also seen stock set ups break with stock tires. It's up to the driver and his power delivery, in my opinion.
Old Dec 16, 2012 | 07:49 PM
  #35
jaredvrose's Avatar
Ok that pretty much answered it.all im wanting is to be able to cruise in 5th at 70 at least.this truck originally had a 5 speed tranny.dont know if the previous owner could have miswired something during the auto swap to make it so powerless..sound ethical?or just plain out i need 4:88s?also i know ive already asked but im gonna ask again is there anyone on here i can buy some used 4:88s cheap?everyone tells me they have them but never offer up for grabs lol.im broke,no joke,aint got a nickel for a coke! And i live around lake talquin.pretty hilly
Old Dec 17, 2012 | 04:41 PM
  #36
jaredvrose's Avatar
Would anyone be willing to trade a 4:88 chunk for a 4:10 chunk?
Old Dec 17, 2012 | 05:03 PM
  #37
CHEEZE's Avatar
I have about 700 miles on my g2 gears. They are 5.29s and I'm running 35s. I pass people on the freeway in 5th. I l
Old Dec 17, 2012 | 05:05 PM
  #38
jaredvrose's Avatar
Got any 4:88s laying around?
Old Dec 17, 2012 | 05:06 PM
  #39
CHEEZE's Avatar
I have the stock 8 inch with 3.7? In it if you want those
Old Dec 17, 2012 | 05:10 PM
  #40
jaredvrose's Avatar
Mine has 4:10s with 33s and an auto tranny that would be worse.im needing these 4:88 gears deaperately lol its killing my power :/
