22re missing and power loss...I need ideas
Old May 10, 2009 | 04:06 PM
1styota4X4's Avatar
So i recently bought a 1985 4runner and have been fixing little things here and there. 22re 5 speed
The problem started a couple days ago. The truck is missing and it has less power. I swapped the VAFM out with one I had no change. I changed out the wires, cap and rotor, it seemed to be a little better then it went back to the way it was. I swapped out the ignitor and coil and still no change.
Can any lead me in the wright direction on this so i can try and get it running better?
Thanks
Old May 10, 2009 | 05:02 PM
JeepRecoveryINC.'s Avatar
I was having a similar problem with my 89. I just put new plugs/wires, new distributor cap, new ecu, injectors, fuel rail and filter, and none of it worked. After all of that time and money it took a pair of pliers and a screw driver and adjusted the throttle and just reved it up a little.
Old May 10, 2009 | 05:08 PM
1styota4X4's Avatar
its a little intermittent but when it happens is through out the power band and it really falls on its face about 3800 or so....
anyone else have a similar problem its currently my daily and i have to work this next week.
Thanks
Old May 10, 2009 | 05:17 PM
toyota4x4907's Avatar
Try adjusting the timing.
Old May 10, 2009 | 05:58 PM
Good idea. Try that one. If you don't know how to or don't want to tackle that first, try cleaning out your manifold and engine with a little sea foam. Suck a little through the vacuum hose and mix some in with an oil change and run some through the fuel system. If you've never used it, don't be alarmed when it smokes like a freight train, it will go away after 10-20 minutes and if you decide to mix it with the oil, change the oil again after 500 miles. For amounts, follow directions on the can.
Old May 10, 2009 | 06:23 PM
1styota4X4's Avatar
The problem is new...I have driven over 800 miles with the truck since i have it. I have tested the 3 vafm that I have all good and the coil good.
Does anyone know how to test the ignitor or is it even testable?
I have tried 2 different ones and i get the same results.
What are the chances that this could be a fuel delivery problem?
Old May 11, 2009 | 08:25 AM
85RunnerSR5's Avatar
It could be a fuel issue. Have you replaced the fuel filter? You've been saying at around a high rpm that it starts lacking power. If it isn't getting enought fuel then it may be running lean. If that doesn't work, you may have an injector sticking.
Old May 11, 2009 | 09:03 AM
1styota4X4's Avatar
I will try seafom in the next couple days if the motor makes it. It has started missing more frequently. I just reasd the FSM on how to test the ignitor today so i am going to try that step next.
I wouldnt think its timing as the dist has not moved and is still tight(unless the dist itself is going out). Which I will be testing that out as well.
Old May 11, 2009 | 10:08 AM
Wardamneagle's Avatar
Bad injector harness connnection or a fuel problem. Change the fuel filter. It's a PITA but at least it's cheap. The electric issues are harder to chase down. Try playing with the harness around the fuel injectors with slightly elevated rpm's and see if you can cause anything to happen or take a multimeter and start checking continuity.
Old May 12, 2009 | 07:40 PM
I forgot to mention and it just popped in my mind. The fuel injector connectors (when they get some age on them) may start to get brittle and crack. The clips are bad to break off. You may have a bad connection on one of your injectors. The best thing to do is to check your connections. If you wanna get a really good look at them you should probably pull your upper intake off. It might look like a lot of work but it's not that bad.
Old May 13, 2009 | 06:17 AM
1styota4X4's Avatar
you guys were right on the the money it was the #4 injector clip was not fully seated. That is y it was intermitant. I wish i would have checkd that first.
Thanks a million guys
icentropy
Sep 16, 2020 02:47 PM
Colington
Mar 8, 2020 09:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
jon.r
Jul 11, 2015 03:34 PM
bryan34w
Jul 6, 2015 05:53 PM
