22RE Intake
there's still an idle air valve, if that's what you're talking about.
the newer ones are heated by coolant instead of electrical so there are different coolant pipes to the heater, etc.
any particular reason why you want to loose the air valve?
Or are you referring to the air flow valve built in to the top of the air filter box? I don't think there is any way to get around that little design clusterf*^k. even the K&N FIPK uses that thing (I think).
If one is serious about redesigning the stock EFI, both MegaSquirt and SDS are viable solutions that can be configured to do, and accomodate for, nearly anything.
http://www.lceperformance.com/22RE-M...-p/1063070.htm
that LCE system looks pretty sweet. between that, the mandrel intake tube, late model bored/port/polish TB and lower plenum conversion with kit goodies (stud kit, thermal barrier gaskets, clean balanced injectors), they have intake for this engine wired. you could buy a whole other beater 4runner for that kind of cash! i want it!
If you want to do a bit more reading. Read through this thread and in particular read the two links at the bottom of post #4.
http://www.pirate4x4.com/forum/showt...ht=22re+plenum
I have a 95 intake plenum, throttle body, and throttle cable sitting in a box and plan on doing this mod at some point. One word of caution, take the time to really clean the donor plenum and throttle body before you install it.
Post back if you do this mod and let us know how it went.
steve miller
Oct 10, 2015 01:40 AM
Tacoma1313
Aug 17, 2015 05:44 PM
