22r running horribly
Old Mar 25, 2017 | 07:50 PM
L5wolvesf's Avatar
Originally Posted by Shagool22
No idea on miles. Previous owner told me the guy before him rebuilt it at some point but that is all he knew. Pistons tell that is the truth they are marked 20 over. The head gasket was not very old at all that's for sure.. The valves are factory valves. I'm wondering if he just did the bottom end? Although I don't know who would rebuild just a bottom end.. not sure what's going on here. Compression numbers were great. 155-160 in the other 3 cylinders. Was the leak down numbers I didn't get. And yes regardless I plan on getting the head a complete makeover. As well as timing chain
He could have just had the valves lapped back then. It sounds like doing the head should get yer truck back on the road again. Have fun doing it.
Old Mar 25, 2017 | 08:23 PM
Shagool22's Avatar
Yup like you said while I'm this far..... all new valves, seats, guides and seals. The cam looks to be in great shape. Rockers look like rockers. Not sure how to tell if they're worn out per say. Have plenty of meat on them.
Old Mar 25, 2017 | 08:49 PM
L5wolvesf's Avatar
Look at the face of the rockers where they can wear or gall. I would only replace the valves that need replacing - but that's just me.
Old Mar 25, 2017 | 09:12 PM
Shagool22's Avatar
Why is that? Seems like one of those things if one fails replace the others while your at it..
What would you do if you were in my situation? As far as the head goes, what would you have them do at the machine shop and what would you replace? Just curious and open to suggestions. First time I've had a valve problem
Old Mar 26, 2017 | 06:53 AM
  #25
L5wolvesf's Avatar
First, what is you intent for the truck - is it a keeper or are you thinking of selling it (presumably for a profit)?
Have the machine shop establish what happened and what parts are good and reusable and which aren't. For me if a good machine shop says a part is reusable I would reuse it - same with rocker arms. The seals are disposable items as are the guides. Valves can be reused after lapping in. But if most of the valves are on the edge of tolerance then do them all. Also make sure the studs are in good shape.
Another completely different thing you could do, if it interests you, is porting or port matching. I haven't done this kind of work on a 22R so I don't know if there are significant gains to be made. You would do this after the head has been machined, if it needs it. Then return the head to the shop for cleaning and assembly. If you do port I would go with a header.
Old Mar 26, 2017 | 07:49 AM
  #26
Shagool22's Avatar
You know, I'm not a 100 % sure yet.. I would really like to keep it but I might end up selling or trading it for the profit. I bought it pretty dirt cheap. but it's a beautiful truck! We will see if it gives me anymore issues after this head job and timing chain..
Old Mar 26, 2017 | 03:16 PM
  #27
Shagool22's Avatar
Found some more issues..
Pulled timing cover off and the timing chain guide was broken in half barely hanging on. And the collar on the smaller oil pump gear is snapped in half!
Oil pan has to come off to replace gasket and remove any timing guide...
Seriously having second thought on rebuilding the whole thing.. I would hate to put it back together as is and have bottom end fail.
Old Mar 26, 2017 | 03:48 PM
  #28
L5wolvesf's Avatar
The guide seems to break on a lot of them, it did on mine. Nothing to sweat over. I don't recall reading about the collar on the smaller oil pump gear breaking.
When you get the pan off loosely reassemble all the broken parts. If you don't have any missing pieces you're most likely OK. Pull off the oil pump and give it a good cleaning too.
Old Mar 26, 2017 | 05:41 PM
  #29
Shagool22's Avatar
Okay will do. I don't thing anything is missing. Oil pan is off and there's nothing in the bottom of oil pan. Everything in the bottom end looks good! All looks brand new damn near..
Old Mar 26, 2017 | 06:10 PM
  #30
Shagool22's Avatar
Another question, is the oil pan supposed to sit on the tie rod like thos or do I got a major steering/suspension issue
Old Mar 26, 2017 | 07:07 PM
  #31
L5wolvesf's Avatar
I would pour the oil through a sifter just to be sure or run a magnet through it. I would expect there to be a piece or 2.
Another question, is the oil pan supposed to sit on the tie rod like thos or do I got a major steering/suspension issue.
​​​​​​​No it shouldn't be touching at all - could be old or incorrect motor mounts too.
Old Mar 26, 2017 | 08:01 PM
  #32
Shagool22's Avatar
Yeah I figured something was wrong there. I'll will look into what the issue is. Thank you for all the help.
Old Mar 26, 2017 | 08:09 PM
  #33
L5wolvesf's Avatar
No problem - good luck.
Old Mar 27, 2017 | 01:24 PM
  #34
atcfixer's Avatar
5 Year Member
If the head ends up warped beyond use, I have a head off a 95 pickup that should be in good shape. Rocker assembly and cam were within new spec, engine had a spun bearing right after a rebuild. Odometer was 16xk. On the rebuilt engine, it's timing belt guides where slightly broken too. I think there's metal ones you can buy, but haven't searched it much.
Old Mar 27, 2017 | 05:34 PM
  #35
Shagool22's Avatar
Back to the tie rod rubbing oil pan, I can find anything that's wrong.. here's a pic of my motor mount.. do you see any issues or are they wrong? And thanks for the luck. I'm gonna need it on this build lol. Previous owner did a hack job on most of it
Old Mar 27, 2017 | 05:37 PM
  #36
Shagool22's Avatar
Are they in anyway directional? Is it possible to put them on upside down or mix up passenger side/ driver side?
Old Mar 29, 2017 | 07:29 PM
  #37
Shagool22's Avatar
More carnage..., blows me away how good this truck ran with multiple bad valves, snapped oil pump gear, broken timing chain guide and now just found a snapped valve spring. Decided to pull all the valves out since I had a min and found this.. #3 exhaust valve
330k on valve train I'd say it's time to replace lol
Old Mar 29, 2017 | 07:37 PM
  #38
L5wolvesf's Avatar
On the motor mounts it looks OK, but maybe not the right part. But that's just a guess. MAYBE the right one is thicker? I would pickup a known correct one and compare them - return if you don't need it.
Old Mar 29, 2017 | 07:40 PM
  #39
L5wolvesf's Avatar
Yeah I would replace them all too. Surprised you haven't found pieces in the pan. If there is a better/upgrade valve spring set it is time to consider it.
Old Mar 29, 2017 | 07:52 PM
  #40
atcfixer's Avatar
5 Year Member
I just pulled engine mounts off a 86 22re. Driver's side bracket uses a bracket (Power steering I think?) to space out for the offset. Passenger side had two thick washers that appeared to be the same thickness. This is the engine mount bracket to engine block. The engine appears to have been freshly redone, and the engine mounts look pretty clean and not rusted up, just oil covered. If you want I could send them to ya with the brackets etc for fairly cheap if you want to give them a shot. There's no marks on the oil pan that I can see anything rubbing, but this is a 4x4 pickup.
Also have the oil pump drive gear and such, looks like it's all in good shape.
