22r no compression on 3 and 4 cyl
Old Jan 9, 2011 | 03:56 PM
cederrowe's Avatar
Just picked up a 85 extra cab in hopes of rescuing it.
Was running like crap, so did a compression test and 0 compression on 3 and 4 cylinder.
When running im getting a loud top end sound, doesn't sound like bottom end as it is higher pitched.
Pulled valve cover resset valve clearance hoping for a valve that wasn't closing all the way. And still no compression on three and four and I mean 0 not even moving gauge.
Any ideas?
Old Jan 9, 2011 | 09:58 PM
myyota's Avatar
How many miles on the engine ?. It could be so many different things, but you will need to pull the head to see whats going on in the engine.
Old Jan 10, 2011 | 03:08 AM
iselloil's Avatar
Blown head gasket.gaskets blown between two cly.
Old Jan 11, 2011 | 09:01 PM
cederrowe's Avatar
wouldn't I atleast get some compression reading with a blown headgasket?
Also no pressure into the cooling system, and no water into oil?
Old Jan 11, 2011 | 09:22 PM
sam333's Avatar
You will have to pull the head anyway.Did the previous owner tell you any problems, or what work was done on it?
Old Jan 11, 2011 | 10:00 PM
cederrowe's Avatar
Found it at a tow yard auction, it was abandoned so no history. Pulling the head tomorrow.
Old Jan 12, 2011 | 04:01 AM
iselloil's Avatar
mine had no coolant/oil mix.The gasket was blown between the clyinders.Compression was really low due to it blowing back thru the intake valves.It blew, sounded like a rod knock, and had no power.Only drove it a 1/4 mile when it happened.
Old Jan 13, 2011 | 08:58 PM
300ultra's Avatar
might have holes burn through pistons??
Bourbonblues
Dec 15, 2017 05:43 PM
Yont283
Sep 20, 2015 10:56 PM
87blyota
Sep 14, 2015 08:38 PM
langry345
Sep 14, 2015 03:36 PM
Gurr
Sep 12, 2015 09:51 PM
