1985 Pickup Steering help.
Hey guys i need help with my steering. I have ALOT of play in my steering which makes me look like a drunk while driving. Also, when i get on the brakes the steering pulls HARD to the right. Its a big problem for me.
My rig is a 85 pickup with 6inch lift 35's if that helps.
My rig is a 85 pickup with 6 inch lift, 35s if that helps.
Assuming that your calipers aren't sticking and making it worse,
You need one or more of the following:
1. An anti wrap bar,
2. Steering swap to cross over,
3. Modify and reattached the torque bar when you're on the road
4. Double check that your u-bolts, shackles and hangers are torqued correctly, new drag link bushings and deal with what doesn't go away.
When I lifted my 4runner I got the same issues.
I tightened my u-bolts(They had loosened up, slightly) and learned to deal with it until I changed to crossover steering.
Because of the push-pull steering, the axle wrap causes the steering to pull when breaking.
I'll just add that my torque arm had gotten loose & I was experiencing a lot of wandering,as well as diving hard to the right on braking! First area I would check/tighten up is BOTH torque arm bolts,then the calipers..then go from there! HTH,Sleepr71.
do you happen to have any pics of the torque arm bolts?
