1985 pickup smog
Old Nov 21, 2007 | 11:13 AM
staticx54621's Avatar
Exclamation 1985 pickup smog
im having trouble trying to get my truck to pass smog first they said my egr valve was out because it wasnt holding pressure so i bought a new one installed it and i still have no pressure in it check all the tubing going to it and nothing is clogged so im just stumped can any one help
Old Nov 22, 2007 | 06:38 PM
anotherjeff's Avatar
Clogged passageways are the cause of most EGR failures. The gas passes thru the plate bolted on the back of the head. The passageways in the head are difficult to rod out with the head on the engine.
btw: "Half Off" at Pick-n-Pull this Fri - Sun (11/23-11/25)! A used head would be about $30. (If you needed one...)
Old Nov 23, 2007 | 12:44 AM
XtraSlow_XtraCab's Avatar
I already got my fill on that one! Dealership charges $130 for a new shift stick. What do I say to that? Well... I better keep it to myself.
Are all of the vacuum hoses hooked up properly? Also the smog pump hoses... even the timing could throw off smog results. THat's the only reason why I failed it. 6deg. off... good Lord.
sandyota
Feb 4, 2021 11:16 AM
adammtb
Jul 27, 2015 11:57 AM
timmJ
Jul 7, 2015 02:01 PM
bryan34w
Jul 6, 2015 05:53 PM
