WHich year axle for the 10inch drums
Old Nov 20, 2007 | 06:23 PM
Bskey's Avatar
I want to upgrade my drums to the 10inch ones...or 11inch ones (I may have my dimensions off, but I want the larger IFS ones). What year truck should I take the axle from to make the swap as easy as possible with as little cutting of wielding as possible. I am thinking it is the '86-'89, but any advice would be appreciated. I want to do this as easily as possible.
Thanks!
Old Nov 22, 2007 | 09:55 AM
91ToyCrawler's Avatar
Anything from 86-95 will work. Just make sure you get the parking brake cbale that goes from drum to drum with it, the ones from the earlier trucks wont work.
Old Nov 22, 2007 | 09:01 PM
Bskey's Avatar
Good call on the parking brake cable! How much cutting, wielding will I need to do for this?
Thanks!
Old Nov 22, 2007 | 09:12 PM
superjoe83's Avatar
the 86-95 axle will bolt up to a 79-85 truck no problem, you will need the 86-95 u-bolts and plates for it to bolt up, the axle tubes are a little bigger on the 86-95, the 79-85 u-bolts/plates wont fit around the axle
Old Nov 22, 2007 | 09:57 PM
dropzone's Avatar
Fossilized
It is highly recommended that you use new U-bolts and nuts when doing axle swaps-spring replacements...
Old Nov 23, 2007 | 02:28 PM
Bskey's Avatar
Great, that's what I need to know! Thanks for your help!!
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
jerusry
Oct 19, 2015 05:28 PM
gieselman
Oct 12, 2015 01:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
