1985 front axle seals.
Old Nov 13, 2008 | 05:09 PM
TRD_yota's Avatar
hey any of you guys know where i can get some axle seals? the ones for the knuckles part i dont know what you would refer that as. but i need those because it is leaking on me and toyota of SB wants an arm and two legs for the seals.
Old Nov 13, 2008 | 05:25 PM
stabmasta's Avatar
You need a knuckle service kit from Marlin Crawler, All Pro, or Trail gear and I would suggest buying the heavy duty marlin crawler seals as well. Gear oil is leaking through the seal and mixing with the grease in the knuckle causing "pea soup" to come out of the backside of the knuckles, correct?
Rebuild kit:
Marlin's seals:
Old Nov 13, 2008 | 05:49 PM
86tuning's Avatar
marlincrawler.com
trailgear.com
the marlin crawler front seals work better than everything else out there.
Old Nov 13, 2008 | 06:09 PM
904_runner's Avatar
Factory seal is on the left, marlin's heavy duty is on the right.
Old Nov 13, 2008 | 06:14 PM
bktaco's Avatar
if you dont have a 54mm thin wall socket, you should get one from marlin at the same time. also, if your wheel bearings are ancient, get those too. IMO its better than getting it all taken apart then finding out that you need to replace them, and then waiting for another few days to a week while your rig is in pieces.
Old Nov 13, 2008 | 07:10 PM
TRD_yota's Avatar
its not my rig but its a family members and we are getting it running again. the bearings checked out and are good. but ill see if he wants to replace those too. thanks alot for the links too. and at 165 for all of it it isnt such a bad idea!hanks alot guys. you think we can put this on in our driveway wit hbasic tools?
waskillywabbit's Avatar
Knuckle Service Kit
http://www.wabfab.org/products/frontaxle/frontaxle.htm
Old Nov 13, 2008 | 07:31 PM
TRD_yota's Avatar
what is the difference between your kit wabfab and the marlin crawler kit?
Old Nov 14, 2008 | 09:12 AM
BigO's Avatar
Probably. I believe the only non-basic tools you will need are the 54mm socket as mentioned earlier, and a pull scale. Also, if you have not already, download the shop manual here for the '85, it is very detailed.
Old Nov 14, 2008 | 06:01 PM
bktaco's Avatar
i've done this job twice without a pull scale. use a torque wrench to spec and you'll be fine. follow directions provided on 4x4wire.com. you will need plenty of shop towels.
make sure to note exactly which shims go where, including direction towards front. this will save you an alignment job in the near future.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
oldirtydirt
Feb 23, 2020 09:30 AM
deepmarsh
Aug 6, 2015 03:44 AM
yourrealdad
Jul 21, 2015 11:13 AM
