1985 front axle seals.
hey any of you guys know where i can get some axle seals? the ones for the knuckles part i dont know what you would refer that as. but i need those because it is leaking on me and toyota of SB wants an arm and two legs for the seals.
You need a knuckle service kit from Marlin Crawler, All Pro, or Trail gear and I would suggest buying the heavy duty marlin crawler seals as well. Gear oil is leaking through the seal and mixing with the grease in the knuckle causing "pea soup" to come out of the backside of the knuckles, correct?
Rebuild kit:
Marlin's seals:
Rebuild kit:
Marlin's seals:
if you dont have a 54mm thin wall socket, you should get one from marlin at the same time. also, if your wheel bearings are ancient, get those too. IMO its better than getting it all taken apart then finding out that you need to replace them, and then waiting for another few days to a week while your rig is in pieces.
its not my rig but its a family members and we are getting it running again. the bearings checked out and are good. but ill see if he wants to replace those too. thanks alot for the links too. and at 165 for all of it it isnt such a bad idea!hanks alot guys. you think we can put this on in our driveway wit hbasic tools?
i've done this job twice without a pull scale. use a torque wrench to spec and you'll be fine. follow directions provided on 4x4wire.com. you will need plenty of shop towels.
make sure to note exactly which shims go where, including direction towards front. this will save you an alignment job in the near future.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
