1985 4runner
Old Nov 13, 2010 | 09:10 AM
85 runner's Avatar
1985 4runner help please
looking for help i have a 85 4runner with problems which is, i start the engine comes on for about 2 seconds and dies i chek the injectors plug,test the power to the wires and they both test 12 volts to my knowl one should be ground pulse any help please.
Old Nov 14, 2010 | 08:08 PM
fustercluck's Avatar
if you have spark, timing and compression (which you do if it runs at all) then it is a fuel supply problem. How old is your fuel pump? How old is your fuel filter? What is your fuel pressure? You could also have a wire grounding you out if the engine dies randomly.
Old Nov 15, 2010 | 05:06 PM
85 runner's Avatar
thanks man this is what i did this morning i disconnected a hose from the intake spray carburator cleaner while starting the engine and it stayed on for as long i was spraying. so there must be something cutting the pulse to the injectors
Old Nov 15, 2010 | 06:15 PM
4Crawler's Avatar
Might be it is running off the fuel from cranking the starter but the AFM is not kicking the fuel pump on. Try the fuel pump test jumper to check that out:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
You need a special tool (noid light) to test the injector pulses, they are too short for most volt meters to read.
Old Nov 16, 2010 | 07:01 AM
Yep, compression, spark/timing or fuel; it'll always be one of those. Just start by eliminating one by one until you find the gremlin.
Flying91
45
Apr 11, 2024 04:39 PM
sandyota
Feb 4, 2021 11:16 AM
adammtb
Jul 27, 2015 11:57 AM
bryan34w
Jul 6, 2015 05:53 PM
