Pre 84 Trucks 1st gen pickups
where do you check tansmission fluid level on 81 pick up
Old Apr 21, 2010 | 06:02 PM
west_89_'s Avatar
where do you check tansmission fluid level on 81 pick up 2.4L 22r 4 speed tranny? sounds dumb but i cant fin a dip stick.
Old Apr 21, 2010 | 06:11 PM
82blueyota's Avatar
check behind the wheel!!!! just kidding it should be a bolt on the pass side of the tranny directly centerd front to baack and top to bottom you will need to remove bolt and insert finger if your unsur if it is low and none comes out when bolt is removed just squirt gear oil into the hole till it over flows replace bolt.bolt lookes like a oilpan drain bolt
Old Apr 21, 2010 | 06:17 PM
dropzone's Avatar
Fossilized
pretty sure it is on the driverside
same place on 4 speeds L43's
Old Apr 21, 2010 | 06:26 PM
82blueyota's Avatar
oh crap i meant driver side was watching wabbits cam and tryng to type
went and got pics of mine look at me giving advise like i think i know somthing
Attached Thumbnails where do you check tansmission fluid level on 81 pick up-dsc00507.jpg   where do you check tansmission fluid level on 81 pick up-dsc00506.jpg
Old Apr 22, 2010 | 07:18 AM
west_89_'s Avatar
lol thanks guys how full should it be? like should it be leaking out when i take the bolt off or should it be lower?
Old Apr 22, 2010 | 07:34 AM
dropzone's Avatar
Fossilized
it should be right even with the bottom of the hole...make sense?
if you have more than that (not sure if you have a side shifting L43 or a top shift L45 or L50) you could have some water in there....unless it is a top shift, sometimes people will fill the transmission through the shift hole..
Old Apr 22, 2010 | 12:55 PM
83's Avatar
83
As mentioned already, if you stick your finger in there, it should get wet. If you don't easily hit gear oil with your finger, you need to top it off. What I do with mine is fill it up until it starts to run out, then put the bolt in. So when I go to check mine (if there's no leak), a very small amount will run out of the fill hole. But as long as the level is right up there at the top of the hole, and you can get some on your finger, it's likely full enough.
Old Jun 16, 2010 | 12:10 AM
WILLTHISIFSGOHIGHER's Avatar
bolt size
Ok so hay guys what size is that bolt mine is kinda rounded off and I need in there. I need the right size so I can pound on a wrench and get her off.
Old Jun 16, 2010 | 05:21 PM
Gov't Mule's Avatar
17mm..
Old Jun 16, 2010 | 08:56 PM
No it cant be 17mm I have got it figured to be between a 23mm and 24mm but the 24mm is too big and 23mm to small so I dont know what it is.
Old Jun 16, 2010 | 08:59 PM
dropzone's Avatar
Fossilized
well mine is 17mm...unless someone used a diff drain plug, than it would be 24mm...
since it is rounded off and the ones you tried don't fit, go to an SAE wrench and start trying them.
Old Jun 21, 2010 | 03:56 PM
nc79toyota's Avatar
i got a 1979 l43 trans and it was a 19mm and the tread was a 18mm x 1.25 bolt i think ..my was rounded off and i used some visegrips to get it off
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
mengquis
Jul 13, 2015 10:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
