Pre 84 Trucks 1st gen pickups
Weird noise in neutral, clutch pushed in goes away!
Old May 24, 2015 | 03:05 AM
Nalu's Avatar
I have the same problem with my 95 4 runner, sounds like a nut is bouncing when I pre
Originally Posted by eric-the-red
Throw out bearings make noise when the pedal is pushed in, that's the only time they move. So it's something other than the throw out bearing, maybe the crank pilot bearing or tranny input bearing. Or the transfer case.
I have the same problem with my 95 4 runner, sounds like a nut is bouncing when I Engage the gas or clutch and the noise intensifies when I go faster, it is a horrible sound that means something is seriously wrong. I changed the clutch and the throw out Bering but noise still there. I going try change the input Bering and see. Other then the noise the transmission shift like brand new. Any input helpful.
Old Jun 28, 2022 | 09:25 AM
gogotransport's Avatar
Any solution?
Originally Posted by joshd
I was playing with the truck again tonight and noticed that if you let the truck roll a little bit, stop it in a different spot, and let off of the clutch that the noise will go away. It seems to only make noise when in just the right spot, almost like once every rotation of the tire. I would think that if it were the input bearing, it would make noise anywhere the truck were parked? Somebody tell me if this makes sense, because now I am ready to rip out my hair, and don't want to put a new clutch in if not needed.
were u able to find any solutions because I am having the same exact issue and the noise goes away with pedal pressed just a bit. And doesn’t always come only in certain positions!
thanks in advance!!!
ViperTT
Aug 14, 2015 05:27 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
yourrealdad
Jul 21, 2015 11:13 AM
PlayAwhile
Jul 20, 2015 11:36 AM
Poncho0206
Jul 10, 2015 06:21 PM
