Pre 84 Trucks 1st gen pickups
Weber Tech/Tuning for newbies and tuning
Old Jul 24, 2014 | 05:48 PM
Soul_keeper's Avatar
I ended up breaking the baseplate trying to make it seal ...
Put some new gaskets on and was tightening it down, ohh well
I think i'm gonna try the lc spiral adapter, just won't be driving my truck till I get it
Old Jul 25, 2014 | 02:50 PM
gillesdetrail's Avatar
Lc is good if the fuel atomisation therory of the plate works but it's a bit expensive. I'm real happy with my transdapt adapter and it's much cheaper.
Old Jul 25, 2014 | 08:01 PM
I guess being in a hurry kinda limited my options.
You're right on the $$$ plus their shipping is over %20 of the price at Lc
hopefully it'll be worth it
Are you using that transdapt on a 32/36 ?
Old Jul 26, 2014 | 05:42 AM
No on a 38/38, I'm a bit anal about port matching and anti-reversion so I needed whip out the dremel to smooth out the transition to my intake but my intake has been ported too so that might be why. It is also made in a funnel shape and is very tall, which adds more cc to the intake plenum which in turn ''should'' help in the higher rpms, but that is only theory.
Old Jul 29, 2014 | 09:19 PM
  #25
Ok, I got the new lce spiral adapter installed and what seems like a good jet combination.
Default:
Main Venturi 26/27
Aux Venturi 3.5/3.5
Main Jet 140/150
Em Tube F50/F50
Air Corr Jet 170/180
Idle Jet 60/50
Pump Jet 50
New:
Main Venturi 26/27
Aux Venturi 3.5/3.5
Main Jet 145/155
Em Tube F50/F50
Air Corr Jet 170/190
Idle Jet 70/60
Pump Jet 55
Best I can tell with my narrowband o2 gauge i'm right around stoich now for cruise and idle. I might try a 180 air on the pri, but it seems pretty good so far. AFM screw out 1 1/2, idle screw out 2
It pulls great, no bog or popping. The big test will be mpg.
Old Jul 30, 2014 | 06:29 AM
  #26
Awesome, great info, there are not enough jet setup info on here, I will be sure to post mine when I'm done.
Old Aug 6, 2014 | 11:47 AM
  #27
vertumnus's Avatar
Emission analysis
its a tutorial about emissions - helpful for those trying to pass smog testing...
Old Aug 18, 2014 | 05:18 PM
  #28
vertumnus's Avatar
passing air care Vancouver BC---1982- r22-weber 32-36
passed air care and the engine runs better
premium 91 octane gas
changed timing advance to 4deg ( factory recommended 8deg)
increased idle mixture jet up one size to 65 ( from stock 60)
increased main jet one size to 145 ( from stock 140)
idle mixture screw = 1.25 turns out ( failed at 1.75 for air care testing) adjusted after air care cause it seemed to run better to 1.50 turns out....
cold choke set to run ok ... idle screw -- set to idle 900rpm
changed catalytic convertor to 3 way ( better at dealing with most and esp N0x's)
Vancouver auto parts # 608204 was only 100.00 this probably the most influential esp on N0x's ( and was what i needed to be reduced ) everything else was very low already...
NOTE: my engine had all the emissions removed or capped off as well as no air pump or EGR valve...
passed air care in Vancouver Canada with flying colors...
got 30 mpg -- tho really i have to look at that again -- i kinda don't believe it -- i'll do other tests and post... while away on holidays...
stock engine r22 with Weber 32-36
new timing chain and new cylinder head... compression on engine within specs....
with 2 lines running on the distributor
I wana say THANKS to this GROUP and everyone's sharing i found it super helpful!!!! hopefully my posting will help others too :-)
Attached Thumbnails Weber Tech/Tuning for newbies and tuning-vacuum-advance-distrib-22r.jpg
Old Aug 19, 2014 | 08:36 AM
  #29
83Toyota88's Avatar
Really good info here. Subscribed.
Old Aug 19, 2014 | 10:11 AM
  #30
enigmaT120's Avatar
30 mpg? Is that a 4WD? Yes please double check that.
Old Aug 19, 2014 | 05:47 PM
  #31
83Toyota88's Avatar
If this is true imma be buying a weber lol. My stock carb is tuned pretty good but not this good. Beat I have seen on my 4wd is 18mpg.
Old Aug 21, 2014 | 09:43 AM
  #32
enigmaT120's Avatar
I have a Weber and only get about 20 mpg, that's why I was curious if his truck is 4WD. I think the 2WD get a lot better mpg.
Old Aug 21, 2014 | 02:09 PM
  #33
I don't think you can get more than 23-25 mpgs with a properly tuned weber on a healthy engine in perfect conditions with a stock truck.
Old Aug 27, 2014 | 10:07 PM
  #34
Before my rebuild I was able to get 30mpg with both the stock carb and the weber.
Gas mileage between the two was comparable for me with my 2wd 88' ... just a matter of slow and steady acceleration and always using high gears.
Since my rebuild I havn't gotten above 28mpg (usually around 25).
note: i'm usually the guy in the slow lane
Old Jan 26, 2016 | 07:52 AM
  #35
trevorthetrekker's Avatar
An update - The links in the first post no longer work. Here:
Weber 38 tuning: http://www.redlineweber.com/html/Tec...as_tunning.htm
You can also go to http://www.redlineweber.com/ then click on "Tech Information" in the left toolbar for lots of good info.
Also, why the hell isn't this thread stickied yet?!
Cheers!
JonG85
Jan 18, 2023 04:31 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
the_supernerd
Oct 1, 2015 09:20 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
93RedKrawler
Sep 29, 2015 02:50 PM
