Pre 84 Trucks 1st gen pickups
Thinking about switching to 20w-50
Old 09-28-2012, 07:22 PM
possum34's Avatar
I run 20w-50 gtx with Lucas in my 22r, I am in a warm climate however. I don't burn much oil. I do have a little blue smoke at start up but not at any other times, and I figure that is valves. I use the thicker oil because once my truck gets hot and you kill it leaks oil like crazy right on top the front drive shaft u joint.
Old 09-28-2012, 08:45 PM
B-Fake's Avatar
Using thicker oil is kind of like putting a band-aid on a cut that needs stitches. It will help, but you're just putting off the inevitable. Half a quart per fill-up is a lot. I would do a leak down test on it to see if it's the rings. If the rings are ok just do the top end, if they're bad do both. If you can't do a rebuild right now thicker oil should keep you from having to top off every fill-up, but I would plan on a rebuild in the near future.
Old 09-28-2012, 10:50 PM
bob200587's Avatar
I think that's how 75% of us are running. Just waiting on something to go wrong that requires a rebuild.
I know i was.
Old 09-29-2012, 12:13 AM
freedyv200's Avatar
is running 10w-40 good for a 150k plus miles 22re?
Old 09-29-2012, 08:32 AM
  #25
RobotMoose's Avatar
My uncle always said to run 20-50 on any engine after 100K miles.
Never wronged me yet.
Old 09-30-2012, 02:17 PM
  #26
Al's Chop Shop's Avatar
are you sure there isn't a puddle of oil on the ground? that's a lot of oil consumption!
heavier weight oil should only be used in hotter climates or when you have problems keeping oil pressure. i use 5-50 full synthetic in my chevy truck because at 313,000 miles the clearances are a little bit wider and it helps keep up my oil pressure.
fix what is consuming your oil! you shouldn't need more than a quart between oil changes on any vehicle.
and do you know for a fact you aren't burning oil out your exhaust? have a friend follow you up a hill, i bet he sees some blue smoke you can't pick up in your mirror while you drive.
Al
Old 10-01-2012, 03:51 PM
  #27
snobdds's Avatar
This poted in the wrong thread....Deleated
Last edited by snobdds; 10-01-2012 at 03:53 PM. Reason: Weird...it went to the wrong thread
Old 10-02-2012, 08:42 PM
  #28
Yopar's Avatar
Rotella 15/40 with some STP added.
gary4runner
09-24-2015 12:53 AM
icentropy
07-14-2015 10:23 AM
Tyler Cunningham
07-11-2015 10:18 AM
Gamble_STi
07-07-2015 07:54 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Thinking about switching to 20w-50
