Pre 84 Trucks 1st gen pickups
security options??
Old Feb 5, 2006 | 02:55 AM
83beater's Avatar
security options??
Where I live, early Toyota 4x4s are stolen like $100 bills in a soup kitchen. When my truck is up and running, I plan on using a "club", dowels in the window channels of the rear slider and an ignition cut-off switch....and if necessary, sitting on my roof with my 300mag. What are other people using for security?
Old Feb 5, 2006 | 03:30 AM
89macrunner's Avatar
lots of people use alarms these days, and no, you don't need power locks or windows to have one.
fuel cut-off switches are popular, or you could pull your efi fuse.
Old Feb 5, 2006 | 09:42 AM
4Rocker's Avatar
I'm not sure pulling the EFI fuse on a 20R will do you a whole lot of good
Old May 9, 2013 | 07:24 AM
jyou9's Avatar
Pull the coil wire!!! They might be able to get in it, but good luck leaving in it!!!
Old May 9, 2013 | 08:35 AM
83's Avatar
83
There are a lot of options for fuel cutoff or switches disconnecting power from the ignition. Your imagination is the only limit to what you can do. There a thread (a little buried now) in the General Vehicle section about it.
You could disconnect the ignition with a hidden switch, and that same switch could connect the ignition to the horn so if someone tried to start it, the horn would go off. You could do a fuel cutoff (if you have an electric fuel pump). You could do a simple switch that cuts off the wires in the steering column from going to the coil when it's flipped. You could pull the wire from the coil before you walk away and throw it in your pocket (a lot of theives are actually pretty smart, and will look for things like that. they'll even look for cut-off switches).
Old May 9, 2013 | 10:07 PM
ConSeann3ry's Avatar
Great idea with the switch to the horn 83.
Old May 10, 2013 | 06:15 AM
83's Avatar
83
Wasn't my idea, I got it from the thread I was talking about. But I agree!
TheBFA
Feb 15, 2020 06:55 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
kbpickens
Oct 2, 2015 03:37 PM
oldblue
Sep 28, 2015 04:07 PM
Rcbc92
Sep 26, 2015 03:00 PM
