Pre 84 Trucks 1st gen pickups
screwed and tattoed
Old Feb 16, 2008 | 02:36 PM
  #41
Whitey13's Avatar
Originally Posted by 85toy
am i stupid or is it impossible to weld aluminum to steel?
In short, you cannot weld aluminum to steel....unless you are camo's friend appearantly.
Old Feb 16, 2008 | 03:37 PM
  #42
4banginRunner's Avatar
magic!
Old Feb 16, 2008 | 06:01 PM
  #43
camo31_10.50's Avatar
talked to the guy...supposedly he said he didnt say that...idk...im just gonna bolt it in there like 4bangin did...so o well
Old Feb 16, 2008 | 06:07 PM
  #44
mine is bolted, self tappered, welded, and brazed on lol totally unsafe, unreliable, not done right in any way, shape or form, and i dont trust it at all, it was only temporary to get it on the street to make it to graduation a while back.... once nice weather rolls around, i'll fix it, no big rush for me tho, got a 4runner to work on now
Old Feb 16, 2008 | 06:15 PM
  #45
heavydm's Avatar
fyi, the reason your fluid looks like that is from water contamination. Always take care of your lubricants if you are off road. I see this every day at work...water and lube don't mix...sux about your damage.. cheers
heavy
Old Feb 16, 2008 | 08:31 PM
  #46
so 4bangin how are you gonna go about fixin ur rusted out floorpans...cuz im at a loss...but i will bolt them in until i figure out a better way to do it...Heavy, i figured it was water contamination...it did get sunk up to the doors about 1month or so before all this happened...never changed the fluids..i meant too..but never did...glad i didnt..then i would have wasted money.. LOL
Old Feb 16, 2008 | 09:16 PM
  #47
Whitey13's Avatar
Is this truck your daily driver?
Old Feb 17, 2008 | 08:28 AM
  #48
yes but i just drive it to school which is like 1 1/2 miles through a town (25mph) occasionally it will get driven more than 15 or 20 miles on state highways...but nothing more...no BIG trips...NEVER anything more than about 30 miles or so. Why?
Old Feb 17, 2008 | 08:35 AM
  #49
Island_Yota's Avatar
I thought my floors were bad. Remember you have body mounts there too so how ever you decide to fix that rust make sure you pay attention to those, without the cab being supported there its gonna be putting alot of stress on the rear cab mounts which are most likely rotten too. I really wish someone would offer replacement floor pans for our trucks though! .
Old Feb 17, 2008 | 08:52 AM
  #50
i dont even know what a GOOD Body mount looks like...so i will take pics of my body mounts...i know they are bad...but idk what they should look like...or how i would go about fixing them since they need to be fixed
Old Feb 17, 2008 | 09:18 AM
  #51
Victor's Avatar
Looks like its time to upgrade to a 5 speed. You are damned lucky not to have flipped.
Old Feb 17, 2008 | 05:33 PM
  #52
yea i thought so too..but i cant find a decent 5spd anywhere...i drove an '87 with a 20R that was swapped in (for some dumbass reason) and it was 5spd....i didnt like it at all...it was hard to drive...i would much rather have my 4spd..9for some reason).. o well...all in all its probably alll gettin put back together and fired up this coming up weekend...(hopefully)
Old Feb 17, 2008 | 06:21 PM
  #53
cut out a piece of 18 gauge steel, roll some beads in it, bend it to fit properly, and spot weld it in then spot weld the inner and outer rockers back on and the body mount on, finish it up with some seam sealer and rhino line the inside and underneath and call it done
Old Feb 17, 2008 | 06:25 PM
  #54
just curious, what do you mean by hard to drive with the 5spd? being an 87 5spd would make it really nice being an even better improvement over the 1st gen 5spds, and the L43 4spd were designed and used in toyota's previous generation 2wd trucks! its a 2wd tranny with a alum. adapter to the t-case, with the highest of all toyota tranny 1st gears, terrible for a 4x4 with bigger than stock tires
Old Feb 17, 2008 | 08:05 PM
  #55
idk...it was probably because im used to my 4spd...not the 5spd....it wasnt hard to drive...just harder to find gears...(i drive a 5 spd geo metro...a 6spd dodge diesel 4x4..and my 4spd truck..)yet this yota felt different...and VERY underpowered for some reason...but no doubt...i would love to have a 5spd in my truck....if i could find one that didnt need to be rebuilt........great...now im gonna hit craigslist AGAIN today...lol
  #56
My floors are only rusty right around the body mounts and where my heels rest on the floor(driver and pass side., same on the passenger side except it extends up the fender well a bit.
What I plan on doing is cutting out some 18 gauge panels and bending them to fit. Then taking some strips of 18 gauge and bending them on the sheet metal break shaping them like the stock "ridges" that are spot welded to the floor and going that route since I dont have access to a bead roller, should work fine. I wish I had access to a wire feed, would make welding the panels in a whole lot easier, I dont want to use any sealer on it, I want it to be all metal.
My only problem is making the indent for the body mounts, im thinking of putting a short length of 4" diameter or around there piece of pipe in the press and pressing the sheet metal down into it to make the indented shape but I have no sheet metal experience so that probably wont work at all, it works in my head though .
Old Feb 18, 2008 | 02:56 AM
  #57
on the floor thats in mine now, all i did for the indent was use a big washer on the bolt and cranked down on it, and it sucked down to look almost like a factory indent...almost
TheBFA
Feb 15, 2020 06:55 AM
zytra
Jan 24, 2019 03:16 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
charlie_fong
Sep 27, 2015 10:06 PM
