Pre 84 Trucks 1st gen pickups
Rear Discs....
Old Apr 12, 2011 | 07:41 PM
BigBluePile's Avatar
Indeed.
Old Apr 12, 2011 | 07:54 PM
slacker's Avatar
Originally Posted by ocdropzone
Hmmm. Disadvantage of the Eldorado calipers is the $$$, kind of defeats the on a budget portion.
true .. but it might give some ideas of "how to" , instead of buying "off the shelf" parts like everyone else does !!
Old Apr 12, 2011 | 08:41 PM
truckman1966's Avatar
that's kinda where my head was at. unique, low cost option that works the way it should
Old Apr 12, 2011 | 09:51 PM
dropzone's Avatar
Fossilized
Wink
Your e-brake system is unique, however other than that is pretty much the typical chevy system :
I got sky's brackets .. Fenco "cadi" calipers .. chev 1/2 ton rotors (center hole lengthened to spec) ... and I will be documenting the emergancy cables , and pad set up ..
Old Apr 13, 2011 | 08:08 AM
  #25
Outsane's Avatar
slackers ebrake starts on his page 6
Old Apr 13, 2011 | 01:56 PM
  #26
prior185's Avatar
rear disc brake
I had another set of front 4runner disc brakes and found a bracket conversion to the rear. The bracket was $30 and line lock you can use a 90'ball valve just check the pressure rating. Cheap and easy. works nice
okamikai
Apr 30, 2018 10:19 PM
kirkrunner
Jul 27, 2015 07:59 PM
SMOD
Jul 27, 2015 01:45 PM
Athansinis
Jul 27, 2015 08:38 AM
icentropy
Jul 14, 2015 10:23 AM
