Pre 84 Trucks 1st gen pickups
Post your gas mileage 1st Gen Truck (79-83 ONLY!!)
Old Dec 6, 2012 | 05:40 AM
  #141
dirtdobberoffroad's Avatar
Originally Posted by 83pingpong
Howdy from the other side of the state!
Nice job on the engine rebuild (and exhaust system work).
Thanks!
Old Jan 11, 2013 | 06:23 AM
  #142
magentawave's Avatar
Anyone know the MPG difference in percentage between a California smogged 22R and a de-smogged 22R?
Thanks
Old May 8, 2013 | 08:42 PM
  #143
dog walker's Avatar
Yes a
about .03%
Old May 9, 2013 | 11:52 AM
  #144
Originally Posted by dog walker
Yes a
about .03%
Thats all?! Geeez, big deal. So I'm guessing the reason people de-smog is because it gives much better performance?
Old May 9, 2013 | 11:59 AM
  #145
83's Avatar
83
I somehow doubt he came up with that number scientifically.
But yes, you're mostly right.
The issues is that after decades, that smog stuff stops functioning correctly. When it's working right, you get good performance and fuel mileage. When things start clogging up, malfunctioning and just not working right, mileage and performance suffer.
Fixing all the emissions stuff is one option, but expensive and difficult. Removing it is the easiest, cheapest way, and it allows things to breathe again. I'd guess performance and mileage would benefit.
Old May 9, 2013 | 06:08 PM
  #146
slacker's Avatar
well gotta say .. I LOVE the 20/22r series engine .. she's a workhorse , and a great engine , no doubt .. but I have built my last one (personally)
I installed the 3.4L with a S/C in my /83 Trekker and will never look back .
with just about 300HP I get 24 MPG hwy .. (lots of city mixed in as well , but mostly hwy )
sorry fellas .. although a great engine in its day .. it's now a dinosaur IMO ...
Old May 9, 2013 | 06:11 PM
  #147
83's Avatar
83
You're probably right. The nice thing is that I know how to work on it. No EFI with flashing codes to figure out what's wrong, just basic mechanics. I'm sure that once you figure out how to work on FI engines, it's great. But I like how simple my engine is.
Old Jun 5, 2013 | 10:46 AM
  #148
Reynoso's Avatar
Im arround 21 mpg city
Old Jun 5, 2013 | 10:49 AM
  #149
Reynoso's Avatar
Im arround 18 mpg city whit 1uzfe
Old Jun 9, 2013 | 07:36 PM
  #150
kneedragger's Avatar
81 short bed, bought brand new off the lot here in san diego in may of 81. She got up to 27 mpgafter break-in. Ofcourse that was when it was a two wheel drive, stripped down model. After conversion to 4X4 twenty years ago I lost 9 mpg , but I saw parts of America two wheel drive can"t get you to.
Old Jun 18, 2013 | 06:53 AM
  #151
79yotastein's Avatar
gas milage 1979
1979 yota with 33x12.50s on it and im getting about 15 in town 18 highway. after lincoln locking my rear end and running around on 8 psi only got 7.6 in town.
Old Aug 14, 2013 | 03:07 AM
  #152
bigdoss82's Avatar
i get about 15 on the highway. Slightly less in town.
Old Aug 22, 2013 | 12:16 PM
  #153
DrinkUrJuice's Avatar
20R 4-speed and stock besides custom exhaust w/header.
17mpg @ 55mph (highway)
13mpg @ 70mph (interstate and pretty much flat out)
14mpg city
Old Oct 6, 2013 | 08:18 PM
  #154
Drewman83's Avatar
Ok so on my 83 Toyota 22 r carb stock running 235 /75-15r wheels I'm getting 27.5 I emptied my tank put exactly 10 gallons and ran the truck till it emptied I went 275.7 miles before it died this is my daily comuter I have copper NGk plugs and a header stock air filter I run a 10-40 oil and I use gas with sea foam every tank so I don't know how it gets that mpg but that's how it comes out
Old Nov 24, 2013 | 01:02 AM
  #155
neockder's Avatar
1980 4x4 4spd, 135k mi, was getting about 9mpg when i rescued it from sitting on a farm and not running. I upgraded to what I thought was a Weber 32/36, and ended up being a weber 38. With new (used) 31" swampers, I was at that point in town getting about 11-12mpg. My friend has a dyno and he got a high altitude jet kit from Weber. It ended up needing the leanest jets in the high altitude kit, and now it's getting 16mpg in town, 21-22mpg on the highway. Not bad for a 33 year old truck! Smog pump and exhaust recirc are still hooked up, but the EGR has a dummy line that is plugged to make it look like it's hooked up.
Old Jan 6, 2014 | 06:46 PM
  #156
jahstrength's Avatar
What did you do to get 300hp out of it?
Old Jan 8, 2014 | 12:34 PM
  #157
zachl1993's Avatar
as of right now my sr5 with 31.50's is getting about 15 around town and about 20 on th highway. its stock other than the tires. anyone have a good website to buy replacement engine parts? i have an exhaust leak and want to fix that.
Old Jan 8, 2014 | 12:47 PM
  #158
83pingpong's Avatar
You can get an exhaust manifold gasket locally. O'Reilly has them, for instance, usually at local warehouse if not in the store. It will take one day, or less for them to get it from the warehouse. It will save you time and cost nearly rthe same amount. Check online sources for prices just so you know if you are paying WAY too much.
Don't forget to be careful (use torque wrench if possible) on the bolts going into that head during install... it is an aluminum head, and you do NOT want to deal with helicoil repairs!
Old Jan 9, 2014 | 05:57 AM
  #159
kawazx636's Avatar
Plenty of sources for replacement engine parts. My go-to sources are:
LCEPerformance.com
engnbldr.com
lowrangeoffroad.com
22reperformance.com
There are others out there, but these are who I have found to be reliable. Getting engine parts isn't the hard task, its finding miscellaneous body, interior and electrical parts that are the hard things to find.
Old Apr 3, 2014 | 02:33 PM
  #160
Tonka83's Avatar
83 22r
average 20mpg I have 83 with dual timing chain 22r with weber carb and fuel pressure regulater. Timing set at advance at 5. No cat with stock style muffler. W series A 5 speed swap with 5.29 gears 35 12.50 15 cooper stt. Can easily do 75 on highway up hill in 5th.
