Pre 84 Trucks 1st gen pickups
Newbie here- with a wrecked 1980 seeking advice
Old Jan 29, 2016 | 11:27 AM
stesrg001's Avatar
Hi every one I had a hilux mk1 1980 truck in the late eighties I have got a wreck that I am trying to rescue any help will be appreciated :-)
Old Jan 29, 2016 | 12:06 PM
highonpottery's Avatar
This is the vendor section.
Old Jan 29, 2016 | 06:08 PM
dropzone's Avatar
Fossilized
Moved from vendor section.
So a bit about the truck would be helpful:
2 or 4wd?
What got wrecked? Front end, rear side??
So this thing has been sitting for 30 years after the wreck?
Old Jan 30, 2016 | 11:54 PM
Terrys87's Avatar
Not much information to go by. Any pictures, what kind of damage, how bad the damage? May not be as bad as it looks or it may just be a total loss and only good for parts.
Old Jan 31, 2016 | 12:22 AM
wyoming9's Avatar
Red face
Been sitting behind the Hog pen since the little mishap with the C-130 and the virgin crew chief ??
Old Feb 5, 2016 | 03:19 AM
stesrg001's Avatar
Hi needs restoring its a 1992 hilux 4x4 I need a rear Tub , axle rebuild kits ? chassis is a mess plates welded on to plates !! its all got to come off , i want this truck looking original :-)
Ste.
Old Feb 5, 2016 | 03:37 AM
Terrys87's Avatar
It sitting that long, you are going to need to go thru the entire fuel system. The tank and lines are going to be nasty. What will look like rust in the tank is actually gas that has broken down and turned to crud. You can clean the tank or may just want to replace it.
Flush your brake and clutch lines as well. I would suggest just replacing your brake calipers, slave cylinders and master cylinder just because the fluid has broken down as well in it.
Old Feb 5, 2016 | 04:08 AM
stesrg001's Avatar
needs rear tub !! truck starts and drives just a mess !!
Old Feb 5, 2016 | 08:10 AM
used or fiberglass bed are pretty much your only option save for patching your existing one. still no pics?
kawazx636
Mar 23, 2023 09:37 AM
Snowking
Jan 29, 2016 05:55 PM
maxds
Jan 29, 2016 08:54 AM
Mikkydee
20
Jan 27, 2016 04:48 PM
