Pre 84 Trucks 1st gen pickups
new 81 4x4 (new to me)
Old Dec 5, 2010 | 07:26 PM
  #241
truckman1966's Avatar
I don't know the history on your truck or what, but IIRC, that's a 2wd oil pan. my 4wd pan is about 2" deep and flat from the oil pump all the way back to between cyl 3 and 4 and then comes straight down about 7" for a short, deep sump and uses a different pick up tube than the 2wd.
Old Dec 11, 2010 | 05:31 PM
  #242
4x4YOTA's Avatar
my oil pan is a 4wd its the same pan on every 4wd 22R Ive ever seen/owned a 2wd oil pan has the pick up tupe in the middle 4wd is at the rear and the 4wd is also angled to lear the fron diff
4WD
http://www.toyotacatalog.net/M1WebGe...6-24E47C7D139E
2WD
http://www.toyotacatalog.net/M1WebGe...5-356FDD40C214
Old Mar 21, 2011 | 08:50 PM
  #243
babakh20's Avatar
truck looks just like mine
Old Mar 27, 2011 | 10:04 AM
  #244
4x4YOTA's Avatar
truck is coming along nicely... got a new top for her off a trekker and also a smitty built bumper but deciede against the bumper but it was all free... took her on a 400 mile round trip and new missed a beat she worked flawlessly I went to jims yota yard and got some goodies... got an SR5 gauge cluster and grille/bezels& light bucket and she has round eyes again... also ordered some 5" shackles from marlin F/R to gain a lil more travel/.5" height I want to do a drop hanger to move my axle forward .5-1" but not sure how comfortable I am trying to weld it on... so after that all gets here I then want to raise my motor 1-2" to clear a tie rod for high steer and raise the tranny 1" to kind of realign things... want to keep her as low as possible and look stock (sleeper look) and thern lockers and winch...
Old Mar 27, 2011 | 10:07 AM
  #245
4x4YOTA's Avatar
is a V6 lock rite locker worth $230 or should I spend the $290 for the V6 aussie?
I want to do a lunch box locker in the rear for now till I can save for a grizly and then move the lunch box to the front and the grizly in the rear or spool the rear and still use a lunch box up front selectables would be awesome but both require more than I wan to do or spend so auto locker are fine by me I use to run spools front and rear and it never bothered me
Old Mar 27, 2011 | 09:05 PM
  #246
Nimyad's Avatar
I spent 425 on a complete 5.29 4-cyl 3rd with a lockright if that helps.
Old Mar 28, 2011 | 11:17 AM
  #247
4x4YOTA's Avatar
Ive got V6 3rds which makes things a lil more pricey...
Ive found the aussie for $289 thru aussielocker.com
and the lock rite for $232 thru lowrangoffroad.com
I have heard stories about guys blowing up lock rites in 4cyl but never in V6 and have never heard of an aussie grenading but the carrier has in both cases with both lockers
Old Mar 28, 2011 | 11:18 AM
  #248
4x4YOTA's Avatar
anyways converted the front end back to the round head lights and it is a big change I almost dont recognize the truck
Old Mar 28, 2011 | 11:29 AM
  #249
Lumpy's Avatar
I'd go with the Aussie. I'm going to once I get to a place to where I can mod again instead of fix.
Old Mar 28, 2011 | 11:33 AM
  #250
ILLINOISYOTADAWG's Avatar
thats a sweet rig man I live in the midwest and winter time suck with all the salt they put on the roads eats stuff up metal termites
Old Mar 30, 2011 | 01:47 PM
  #251
4x4YOTA's Avatar
your right I might aswell do it right the first time ... most likely Ill go aussie front and spool rear unless I can get a good deal on some 4.30 elockers or find a 4.56 elocker
Old Mar 30, 2011 | 09:14 PM
  #252
4x4YOTA's Avatar
got my trekker top painted and installed... now just need to find a trekker bed
Old Mar 31, 2011 | 06:57 AM
  #253
Lumpy's Avatar
For as much as you drive this why would you spool the rear? Just chew the hell outta the tires. Just me talking.
Old Mar 31, 2011 | 06:59 AM
  #254
Lumpy's Avatar
I'm liking the hood pins! My latch sticks open I have to use a screwdriver to push the lock back into place. Instead of fixing I might do the pin thing...
Good score on the trekker topper!!!
Old Apr 1, 2011 | 10:36 AM
  #255
4x4YOTA's Avatar
right now Im all talk about lockers, Im getting anxious about wheeling this summer... Ill most likely spend the money on a winch and call it good for this year and then start saving for E-lockers for next season... and do everything right from the start rather than wasting money just cuz I can
and thanks for the compliments
did the hood pins cuz I got sick of the latch rattleing around and not always opening...
Old Apr 1, 2011 | 10:40 AM
  #256
4x4YOTA's Avatar
Im looking to possibly get the smittybuilt XRC8 w/synthetic line and the low range large adapter and weld it to the front of my frame and mount/hide the winch under the stock bumper
like this truck did
Old Apr 1, 2011 | 10:43 AM
  #257
Lumpy's Avatar
That there's a good idear.
Old Apr 9, 2011 | 10:36 AM
  #258
4x4YOTA's Avatar
what would be a good way to mount a oplate like that? just weld it to the front of my frame?
Old Apr 9, 2011 | 10:43 AM
  #259
SCToy's Avatar
I read somewhere on here to buy or make a reinforcement plate for the front of the frame and weld nuts to the back of it in the same pattern as the winch Plate of your choice.
Old Apr 10, 2011 | 09:23 AM
  #260
4x4YOTA's Avatar
i dewfinately plan to plate the from and add braces/gussets... just having a hard time finding a good wintch plate
i like this one from low range
http://www.lowrangeoffroad.com/index...unt-plate.html
or even the smitty built mount looks good and can find it locally
