new 81 4x4 (new to me)
#241
I don't know the history on your truck or what, but IIRC, that's a 2wd oil pan. my 4wd pan is about 2" deep and flat from the oil pump all the way back to between cyl 3 and 4 and then comes straight down about 7" for a short, deep sump and uses a different pick up tube than the 2wd.
#242
my oil pan is a 4wd its the same pan on every 4wd 22R Ive ever seen/owned a 2wd oil pan has the pick up tupe in the middle 4wd is at the rear and the 4wd is also angled to lear the fron diff
4WD
http://www.toyotacatalog.net/M1WebGe...6-24E47C7D139E
2WD
http://www.toyotacatalog.net/M1WebGe...5-356FDD40C214
4WD
2WD
#244
truck is coming along nicely... got a new top for her off a trekker and also a smitty built bumper but deciede against the bumper but it was all free... took her on a 400 mile round trip and new missed a beat she worked flawlessly I went to jims yota yard and got some goodies... got an SR5 gauge cluster and grille/bezels& light bucket and she has round eyes again... also ordered some 5" shackles from marlin F/R to gain a lil more travel/.5" height I want to do a drop hanger to move my axle forward .5-1" but not sure how comfortable I am trying to weld it on... so after that all gets here I then want to raise my motor 1-2" to clear a tie rod for high steer and raise the tranny 1" to kind of realign things... want to keep her as low as possible and look stock (sleeper look) and thern lockers and winch...
#245
is a V6 lock rite locker worth $230 or should I spend the $290 for the V6 aussie?
I want to do a lunch box locker in the rear for now till I can save for a grizly and then move the lunch box to the front and the grizly in the rear or spool the rear and still use a lunch box up front selectables would be awesome but both require more than I wan to do or spend so auto locker are fine by me I use to run spools front and rear and it never bothered me
#247
Ive got V6 3rds which makes things a lil more pricey...
Ive found the aussie for $289 thru aussielocker.com
and the lock rite for $232 thru lowrangoffroad.com
I have heard stories about guys blowing up lock rites in 4cyl but never in V6 and have never heard of an aussie grenading but the carrier has in both cases with both lockers
#251
your right I might aswell do it right the first time ... most likely Ill go aussie front and spool rear unless I can get a good deal on some 4.30 elockers or find a 4.56 elocker
#253
For as much as you drive this why would you spool the rear? Just chew the hell outta the tires. Just me talking.
#254
#255
right now Im all talk about lockers, Im getting anxious about wheeling this summer... Ill most likely spend the money on a winch and call it good for this year and then start saving for E-lockers for next season... and do everything right from the start rather than wasting money just cuz I can
and thanks for the compliments
did the hood pins cuz I got sick of the latch rattleing around and not always opening...
#256
Im looking to possibly get the smittybuilt XRC8 w/synthetic line and the low range large adapter and weld it to the front of my frame and mount/hide the winch under the stock bumper
like this truck did
like this truck did
#260
i like this one from low range
http://www.lowrangeoffroad.com/index...unt-plate.html
or even the smitty built mount looks good and can find it locally
