Pre 84 Trucks 1st gen pickups
my '83 p/u
Old Mar 7, 2012 | 06:17 AM
Bingle's Avatar
That's the 2 piece adaptor. Enlarge the pic and you'll see the 2 slabs of aluminium. I ran that kit for a while and it's "fine", just prone to leaks. If you're planning on running that setup for a long time, spend the extra and get a good single piece adaptor like this mabee? http://www.lceperformance.com/Spiral...-p/1033028.htm
If, like myself at the time, this is something to run until you have the money to buy the offy dual plane manifold or whatever (among sooooo many other fun engine and suspension mods), then it should be fine. I think I ran the two piece for about a year and it didn't leak, but I gooped it up with rtv pretty heavy if memory serves (this was 12+ yrs ago).
Old Mar 29, 2012 | 12:16 PM
quazy65's Avatar
ok so i was wondering since i already have a rebuild kit is it easy to rebuild the stock carb. or is it even worth it.
Old Mar 29, 2012 | 04:13 PM
quazy65's Avatar
also i just got taken a outlaw carb off a 1986ish mitz mightymax (my dads truck and he wasnt very happy about it but he will get over it). i was wondering if it might bolt up? i also got the conversion plate also but havent yet took it off.
Old Sep 22, 2012 | 04:50 PM
quazy65's Avatar
havent done much to the truck but was wondering is the rough country 3" lift kit w/ 4 RC Hydro 8000 is a good lift choice? or is there better ones out there?
Old Sep 25, 2012 | 06:13 AM
  #25
Bingle's Avatar
I think that's a decent lift. PM kawazx636, or maybe he'll chime in, but I believe that's the lift he's running and he's happy with it.
Old Sep 25, 2012 | 11:00 AM
  #26
kawazx636's Avatar
Good thing I am subscribed to this post! Bingle was incorrect (no hard feelings), I DO NOT like the 3" Rough Country lift kit that I bought. I knew it was a lower level kit, but I simply bought it to get rid of the ridiculous 7.5" lift that the PO had on my truck so I could keep my truck on the road until I ripped it down for a restore this fall. My RC kit rides stiff as ˟˟˟˟ and hardly has any flex. For a quality suspension, you are going to spend quality money! That being said, I will be going with the product offered by WabFab or LC Engineering.
If you don't really care about ride quality and performance, then by all means go with RC. But make sure you save some extra cash to see the Chiropractor everything you go for a spin!
Old Sep 25, 2012 | 11:06 AM
  #27
Bingle's Avatar
No offense taken! Was just pretty sure that was the lift you had so you would be someone who would know. So, "Rough Country" is a very apropreate name then.
Old Sep 25, 2012 | 04:03 PM
  #28
quazy65's Avatar
ok thanks i have been looking for a while and i saw that one and thought i would ask if yall knew about it and im glad i did now so i guess i will go look at wabfab and lc then
Old Sep 26, 2012 | 06:15 AM
  #29
Bingle's Avatar
I believe all-pro offroad springs get reviewed highly as well.
Old Sep 26, 2012 | 11:39 AM
  #30
85toy's Avatar
yes all pro springs would be what i would use. rough country,procomp and skyjacker are all crap IMO. trail gear springs are ok, just ok. they will perform more like the all pro spring do but they are known to break and/or sag over time.
Old Sep 26, 2012 | 04:24 PM
  #31
quazy65's Avatar
ok thanks for the info so i got another one to ask about, is the Trailmaster lift good, ok, or bad?
Old Sep 28, 2012 | 07:25 AM
  #32
quazy65's Avatar
does anybody know at all?
Old Sep 28, 2012 | 04:22 PM
  #33
slacker's Avatar
middle of the road
Old Oct 2, 2012 | 01:09 PM
  #34
quazy65's Avatar
Thanks for the help it really helps considering I'm new to this stuff and I will do some more research on the lifts to see which one will fit best for me.
Old Oct 2, 2012 | 05:07 PM
  #35
toastyjosh's Avatar
You may want to look a Old man emu lifts, you could get the front springs 89 each, then get some shackles. The rear you could get a add a leaf and shackle. Then some new shocks. Some people love the OME stuff some people hate it. This is what I think I am going to do. JustDSM had the OME kit so you may ask him about the ride.
Old Oct 2, 2012 | 05:09 PM
  #36
toastyjosh's Avatar
http://www.rocky-road.com/4runner.html
Old Oct 25, 2012 | 10:37 AM
  #37
quazy65's Avatar
ok havent done much and thanks to all of yall who helped with lift questions but that gets to be put on hold cuz the floor is rusted though way more than i thought. so i was wondering could a 82 or 83 2wd cab fit on a 83 4wd truck with not a lot of modifacations?
Old Oct 25, 2012 | 08:52 PM
  #38
Little Elger's Avatar
If you still need a long bed, I have one from a tailgate donor truck, I also have my old gate that can prolly be fixed. In Oklahoma.
Old Oct 26, 2012 | 08:11 AM
  #39
quazy65's Avatar
srry i done found one that needed a little work because of surface rust on side and two smallish rust holes in the bed.
Old Oct 29, 2012 | 10:23 AM
  #40
quazy65's Avatar
so does anyone know if a 1982 2wd cab will fit a 1983 4wd frame?
greasyglue
Dec 12, 2015 12:57 PM
1994Toyota4X2
Aug 22, 2015 06:27 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
