Pre 84 Trucks 1st gen pickups
My 81 pickup
Old Sep 27, 2010 | 09:35 AM
Nimyad's Avatar
With ruf and chevy 63s i got 3.5 in of lift. Changes the fronr shackles but not the front perch.
Also i second the clogged jet or idle screw moving about.
Old Sep 30, 2010 | 12:19 PM
JagerFiend's Avatar
Alright sorry for not giving quick responses on here. Ive had alot of stuff going on lately.
but anyways i think i solved the carb problem. It seems the guy that had it before me ran the two wires coming off of it to an aftermarket fuse panel deal. The fuse for the carb blew. after replacing it everything runs fine. Silly huh? I am still going to get at the carb and give it a good cleaning cause it seems like a good idea. Thanks for all the speedy replys. i think i need to adjust the fuel ratio a little, cause it seems to run a little rich.
As for the lift. im pretty set on the chevy spring lift. Just at this point the funds need to come in. had a big credit card bill i had to pay off lol.
Old Sep 30, 2010 | 12:55 PM
yoder519's Avatar
x2 on keepin it a little lower fro 33s.when you regear, your better off to go 5.29s. that way when you bigger tires, you wont be undergeared. thats a swwwwwwwweeeeeeeeeeettt 1st gen. love the wheels
Old Oct 2, 2010 | 06:32 PM
JagerFiend's Avatar
so everybody seems to think that i should keep it lower. how much lift are you talking? think the chevy sway would be too much?
and thanks. im gonna hold onto this truck till i have kids. lol i love it
Old Oct 24, 2010 | 03:13 PM
  #25
JagerFiend's Avatar
So i have a few questions that i cant seem to find by searching around.
my front suspension is really sagging so i decided to go ahead and just do the lift. ive located some chevy springs and am going to start buying up all the parts i need to perform the lift... slowly. so far my list is:
Chevy springs with the shackles
Front spring hanger
longer shock absorbers
shims for pinion angle?
anything else?
so i my question is once the lift is installed, is it going to affect my steering? and will i need to change/lengthen anthing?
i am a poor 18 year old and want to run stock steering until i can afford the highsteer
Old Oct 24, 2010 | 03:39 PM
  #26
myyota's Avatar
Depending on how much lift you end up with, you might need a new drive shaft.
Old Oct 25, 2010 | 02:55 PM
  #27
JagerFiend's Avatar
On the pirate4x4 faq it says 3-4 inches of lift, so if it gave me four do you think i would need a longer driveshaft?
if so the current driveshaft i have is a custom one that i believe is shorter than stock to accomodate the longer transmission.so maybe finding a stock one would do the trick.
any idea if the steering would require new parts?
Old Nov 2, 2010 | 08:25 PM
  #28
wentz912's Avatar
Yes you are going to pretty much have to do crossover steering in order to not have to do some janky stuff to the factory steering since the front axle will be way forward of factory.
Old Jan 6, 2011 | 02:46 PM
  #29
JagerFiend's Avatar
So I haven't made many updates on my truck for a while. I have just been doing research on here and pricing parts. However I am now almost ready to start dropping some of my savings on parts.
I am set on doing the chevy spring swap in the rear and doing rears up front. I am planning on buying low range off roads kit for the swap and I have already acquired the chevy springs. I have some days off from work coming up and plan on starting then. I would be more than happy to do a full write up documenting the process. Possibly even video it if anybody thinks it would benefit the community?
Now my questions (or thoughts for discussion rather) are as follows:
I read through the newbie modification thread and entirely agree that the steps for upgrading a vehicle should be as listed there.
However something I have found, many others have probly too, is that upgrades and modifications to a truck are very much linked. Ie: lift without tires is pointless, high steer without lift is impossible, tires without gears is alot less effective, gears without tires makes for a difficult drive... Yada yada.
Edit: not everything I wrote showed up.
Here's the rest.
So with me being on a limited budget I have been looking at what to do and when and the jumble of linked upgrades has left me running in circles.˟
My current plan is to go ahead and do the lift, high steer and associated tweaking required and find a set of 35" mud tires. This should cost me around 200 for the rest of the lift parts 350 or so for the high steer and steering box. And 500-1000 for tires. I am aiming for around 1000 dollars for this first step. Then I will have everything in place for when I regear and lock the rear end up. Plus If the bigger tires are driving mr crazy I can use my current ones until I get the drivetrain parts.˟
How does this sound to y'all?
Old Jan 11, 2011 | 06:51 PM
  #30
JagerFiend's Avatar
Picked these guys up today from somebody on craigslist.
5.29 with gears professionally installed.
Probly gonna pick up some 35 inch tires here soon too
Old Jan 11, 2011 | 07:26 PM
  #31
BoredOutnJackdUp's Avatar
I've picked up so many sets of 35's off craigs. Cheap too.
I found some 35x12.5 in aluminum rims at like 50ish percent that i traded wheel spacers for.
Nice find on the gears too!
Old Jan 12, 2011 | 09:00 AM
  #32
JagerFiend's Avatar
Yeah I'm always shopping craigs for tires and other parts. I was also looking at treadwright. They seem like a really good deal. Anybody on here running those?
Before I say what I payed for the gears. What would you say would have been a good deal for em'?
Old Jan 12, 2011 | 05:44 PM
  #33
i'd say 300 would be a damn good deal. but i guess it really depends on the brand of gears.
Old Jan 12, 2011 | 06:02 PM
  #34
camo31_10.50's Avatar
complete assembled 3rds..that are not used i don't guess?
heck $500-$700 would be enough for me.
$300 would be amazing lol
Old Jan 12, 2011 | 06:22 PM
  #35
JagerFiend's Avatar
complete assembled thirds brand new yukon gears.
If people wanna keep guessing i can wait on telling what i payed lol. sounds like your all havin fun
Edit: I have what is probly a stupid question. but front and rear thirds aren't different are they? As in i can put one of these in the front and one in the back of my truck?
Old Jan 12, 2011 | 06:25 PM
  #36
gahh you're mean.
if i get close will you tell me?
Old Jan 12, 2011 | 06:35 PM
  #37
JagerFiend's Avatar
Originally Posted by camo31"10.50"
gahh you're mean.
One more guess and then ill tell you. haha
your were pretty close the first time
Old Jan 12, 2011 | 06:37 PM
  #38
how about $550?
Old Jan 12, 2011 | 06:38 PM
  #39
$385 is my final guess!
Old Jan 12, 2011 | 06:41 PM
  #40
$600?
$800?
