Pre 84 Trucks 1st gen pickups
L50 input bearing
Old Feb 27, 2013 | 06:16 AM
  #41
83's Avatar
83
Niiiice!
Old Feb 27, 2013 | 06:48 AM
  #42
SCToy's Avatar
Word of advice, fill the gear oil up before you put it in the truck because it takes forever through the fill hole. I taped a funnel to the shifter and ran a hose through the shifter assembly down to the fill hole. Gear oil pours real slow though.
Old Feb 27, 2013 | 07:44 AM
  #43
83's Avatar
83
Yep. I've sat under my truck for a long time, with a little hand pump, pumping fluid into the transmission...then t-case...I was probably under there pumping oil for almost an hour.
Old Feb 27, 2013 | 05:19 PM
  #44
catfish21's Avatar
Can someone tell me if it's my transmission or what but when I get to around 60 mph it gets so loud like a deep roar and vibrates the truck bad. I really need to diagnose this problem what could this be its a 1982 pickup 4x4 and I'm a new owner just trying to solve some issues I have and get more familiar with the truck
Old Feb 27, 2013 | 05:39 PM
  #45
SCToy's Avatar
Sounds to me more like your tires aren't balanced. The transmission bearings sound bad in certain gears. If its the input bearing it will whine in neutral sitting still.
Old Feb 27, 2013 | 05:56 PM
  #46
catfish21's Avatar
I really don't think its the tires I mean it sounds fine but when I get to 60 all of a sudden it is so loud I just can't explain it and a vibration, I would think if it was tires it wouldn't just so it at a certain mph
Old Feb 27, 2013 | 05:57 PM
  #47
catfish21's Avatar
I'm just stressed out about it and want it all to work out and thanks for the advice
Old Feb 27, 2013 | 06:13 PM
  #48
cman1's Avatar
my 4-spd does that at 35 mph,im pretty sure third gear is the culprit,goes away at 40.my 5 spd is sitting on the floor waiting for a new clutch so i can swap em.
Old Feb 27, 2013 | 06:16 PM
  #49
cman1's Avatar
go through all your u-joints, check your diff flanges for looseness.they have a tendancy for your pinion nut to back off and the flange loosens enough for a pretty good vibration.
Old Feb 27, 2013 | 06:21 PM
  #50
SCToy's Avatar
Could be a driveshaft. Doesn't get noticeable untll
You get it spinning the right speed. Put the rear on jack stands and run it through the gears and watch it.
4Xtruck
16
Sep 24, 2015 09:38 AM
YotaPagota
Sep 20, 2015 06:24 PM
Adam Edgar
Sep 20, 2015 03:24 AM
93toyoguy
3.4 Swaps
10
Sep 18, 2015 04:16 PM
justdifferentials
Sep 5, 2015 06:52 PM
