Pre 84 Trucks 1st gen pickups
I am losing coolant from the back of my cyl. head
Old Jan 21, 2014 | 12:25 PM
thetundrawolf's Avatar
Hi,
So i have had this ongoing problem of losing coolant. I could never figure out where it was coming from, until I got under my RV and saw the back of the head smattered with coolant.
It looks like it is leaking from the exhaust transfer cover, that goes to the EGR.
Is there anything back there that's close to the coolant? Could the head be cracked?
Old Jan 21, 2014 | 12:39 PM
83's Avatar
83
There is a coolant passage bolted onto the back of the cylinder head. Not sure how hard it is to get at with the engine in the truck...I've only ever seen it when I had the head off.
It could be that, a cracked head, or a headgasket leak. Coolant passage is probably the most likely.
Old Jan 21, 2014 | 12:44 PM
I thought it was a passage for exhaust gasses for the EGR?
Old Jan 21, 2014 | 12:49 PM
Stetson_md's Avatar
Nah the egr gose through the head. Just took mine off last nite:-)
Old Jan 21, 2014 | 01:34 PM
83's Avatar
83
That's because it's known sometimes as the EGR cooler
http://www.google.com/imgres?safe=ac...ed=0CGQQrQMwBA
https://www.yotatech.com/forums/f116...e-head-224780/
Old Jan 21, 2014 | 06:57 PM
kawazx636's Avatar
The EGR crossover plate on the back of the head is not a coolant passage. It routes the exhaust gases from the exhaust rail incorporated into the driverside of the head to EGR valve on the rear passenger side of the head. It does have coolant running accross the back side of the plate, but the the actual "crossover" portion of the part is for gases. It is possible to have a coolant leak there and it is nearly impossible to remove it without taking off the head.
bigjstang
Jun 2, 2025 03:56 PM
Colington
Mar 8, 2020 09:51 AM
smiley52
Jul 11, 2015 05:16 AM
Avenged
Jul 9, 2015 07:55 AM
elwood73
Jul 5, 2015 07:07 AM
