Pre 84 Trucks 1st gen pickups
Hissing noise from EGR valve?
Old Oct 16, 2019 | 06:35 AM
IdleIvey's Avatar
I was replacing some old vacuum caps on my 76 and after starting the engine up I noticed a hissing sound coming from what I think is the EGR valve. Thing is the PO de-smogged the truck when he installed the Weber carb so I shouldn't have an EGR valve right? I'm guessing PO was to to cheap/lazy to pull the EGR and block it off. I'm also assuming I should go ahead and do that. Anyway I've attached a video for reference.
Old Oct 16, 2019 | 11:15 AM
Punjab's Avatar
Yeah you definitely want to pull that off and plug the hole on the side of the head. Make a plate or buy the kit that LCEngineering makes.
Old Oct 18, 2019 | 05:28 PM
13Swords's Avatar
5 Year Member
LCE EGR Block Plate Kit : https://www.lceperformance.com/EGR-B...-p/1016038.htm
Old Oct 18, 2019 | 09:57 PM
Co_94_PU's Avatar
Pretty sure what I am seeing here is an egr valve with the modulator port capped and the "output to intake" venting to the engine bay. ?
Nice move previous owner..
Old Oct 19, 2019 | 07:46 AM
IdleIvey's Avatar
All sorts of fun little suprises left by the previous owner. Ordered the block plate!
Old Oct 19, 2019 | 08:54 AM
IdleIvey's Avatar
Pulled off the heat shield to start and found this little surprise.
Old Oct 19, 2019 | 11:10 AM
IdleIvey's Avatar
420 braze it boys!
Old Oct 19, 2019 | 04:57 PM
Punjab's Avatar
Haha yep close it up!
Old Oct 20, 2019 | 08:25 AM
rickc5's Avatar
Smile
Originally Posted by IdleIvey
420 braze it boys!
Or, buy a header from LCE when you order the EGR block-off plate.
Old Oct 20, 2019 | 12:05 PM
IdleIvey's Avatar
Headers would be a cool upgrade but I'm on a budget. LCE headers are like 360 and I imagine I might to do some fab work on the exhaust to get it to line up.
Brazing would be a lot cheaper if I can find someone with an O/A torch.
ctcost
May 15, 2009 04:25 PM
MaximRecoil
Mar 14, 2009 08:22 AM
montanatoy
Apr 26, 2007 03:16 PM
the00flaw
Jan 12, 2006 02:24 PM
Bumpin' Yota
Sep 22, 2004 12:39 PM
