Pre 84 Trucks 1st gen pickups
Old Apr 16, 2009 | 07:48 AM
  #521
idayota's Avatar
Originally Posted by gmack192
this is how I found my 83. It had been sitting in a field for almost 5 years.
stripped and ready for the rebuild.
here's how it sits now,
the interior is done and the doors are hung. the engine is still @ the machine shop. Hard to believe it ran, cracked head (4 cracks) DEEP gouges in the #1 cylinder and a 1/2 inch of MUD and rust in the oil pan. going .40 over, cam, header, and weber. when I recover from the engine build I'm going to regear it, 5.29's and aussies. then tires Q-78 Swampers.
i really like the truck. good work getting it back into running shape.
to get your post to turn out more readable, just hit return after every line (like after the image code [img]blablb[/img] hit the return key. after a sentence, hit the return key).
Old Apr 16, 2009 | 09:59 AM
  #522
gmack192's Avatar
the paint is Krylon flat kahki
and thanks for the encouragement
I've been working on her for about 5 months
the engine was a BIG set back, it ran when I got the truck (started on the 3rd try, we used a jump box and 3 sparkplug wires off of a junk car)
Old Apr 16, 2009 | 03:31 PM
  #523
dropzone's Avatar
Fossilized
good build.
Did you keep those turbine wheels that are on the truck in the bush picture? I always loved those. They would look awesome black with the Khaki...
Keep us posted on your progress
Old Apr 17, 2009 | 04:53 AM
  #524
gmack192's Avatar
yup I still have the turbo wheels not sure which ones I'm going to use I like both, but the steel wheels balance better. I really want factory stock steel wheels just think they're cool
Old Apr 17, 2009 | 04:55 AM
  #525
gmack192's Avatar
went to the machine shop yesterday, the second crank I took him is worse than the original one. I guess I'm going to bite the bullet and buy a new one. Any suggestions on a GOOD company that sells Toyota cranks???
Old Apr 17, 2009 | 05:31 AM
  #526
83's Avatar
83
Try engnbldr.com
Old Apr 17, 2009 | 05:41 AM
  #527
gmack192's Avatar
He doesn't sell crankshafts but Japan Engines.com sells "brand new" cranks for $110.00.
has anyone delt with them before??? are they reliable??
Old Apr 17, 2009 | 08:32 AM
  #528
83's Avatar
83
If you're looking for more advice on it I'd post a new topic.
I don't have any experience with them. Seems like maybe engnbldr would be able to point you in the right direction, though?
Old Apr 17, 2009 | 04:34 PM
  #529
4banginRunner's Avatar
I started this thread and I've havent posted a pic in like 2 years...
*Check the build thread for details..*
As she sits today, finally got her moving, just have to change/fill all the fluids, run the taillights/turn signals, and run my tailpipes
Crappy cell pics
Old Apr 18, 2009 | 09:05 PM
  #530
koolyota's Avatar
Heres a good one of my project yota!
I know the pic is too small
Im not sure how to enlarge the photo though
[IMG][/IMG]
Heres the current parts list
1980 Toyota 4x4 Hilux Long Bed
Custom Brown Metallic 4b4
-1985 22RE Motor
-Off-road Solutions Engine Harness
-Motor Mounts
-1983 EFI Fuel Tank
-OEM Fuel Pump
-Denso Fuel Filter
-Recent top end Rebuild
-Crane mild camshaft
-Rebuilt L52 5speed
-Marlin Crawler Heavy Duty Clutch Kit
-Marlin Crawler Resurfaced Flywheel
-OEM Clutch Slave Cylinder
-OEM Clutch Master Cylinder
-LC Engineering SS Ceramic Headers
-Magnaflow Hi-Flow Cat
-Denso O2 Sensor Pre-Cat
-Denso Alternator
-NGK Iridium Plugs
-NGK Wires
-3” K&N Cone Filter
-Optima Red Top
-Old Man Emu Shocks
-Old Man Emu Steering Stabilizer
-Old Man Emu Leaf Spring w/HD Rears
-Old Man Emu Shackles/Pins/Bushings
-V6 IFS front brake calipers
-FJ 60 Land Cruiser vented rotors
-FJ 80 Non ABS Master Cylinder
-Crown Performance SS Brake Lines
-Mickey Thompson 15x8 Rims
Old Apr 20, 2009 | 08:26 AM
  #531
gmack192's Avatar
good looking truck
Old May 5, 2009 | 12:08 PM
  #532
yotaboy82's Avatar
well here are some pics of my toyota as it sits now...
Old May 5, 2009 | 07:23 PM
  #533
vkasm1's Avatar
sorry cell phone pics
Old May 6, 2009 | 09:09 AM
  #534
scooper's Avatar
What suspension setup and tire size are you running there VK?
Old May 6, 2009 | 04:35 PM
  #535
vkasm1's Avatar
Im running 63 chevies and rears up front with 12 inch bilsteins all around. Tires are 35 maxxis big horns.
Old May 6, 2009 | 05:18 PM
  #536
scooper's Avatar
Thanks VK, I think I'm going to look into what all is involved in doing this setup. I love the way it looks on your truck! If you have any tips, info or advice for this swap could you send me a PM?
Old May 6, 2009 | 08:49 PM
  #537
TRD83Yota4x4's Avatar
Dec/83 Toyota 4wd Daily Driver, Trail rig
picked it up for $800
20R eww #3
truck now has a early duel chain 22R new timing chain kit.
cadillac seville 86 rear bench seat
Feb/79 Toyota 2wd Project
picked it up for $200 motor needs work.
Craigslist pic's
this is when i got it home. i test fitted the 4wd grille.
here it is now. it is nowhere near finished. it has only begun
got the rims for $200 from a friend they are off of a 300x 18's
the fenders, hood, doors with wing windows are from a 4x4
camry or celica seats not sure. picked them up already fitted for a 79-83
cadillac seville 86 center counsel
i love these steering wheels
eww
plans:
remove rear bumper and duel tails
cheap $200 rebuild kit from ebay + weber
85-88 front control arms and 2in drop spindles
tweak torsion bars 1in
drop the rear with some 3in blocks
4wd rear fender flares
1.5in wheel spacers
future plans:
full tube chassis with air bags and 300zx IRS rear end
mild built 22re bottom end mild built 20r head
tubular turbo header with a holset H1C
efi manifold custom fitted to 20r head
big injectors from a volvo 850 turbo
spark via MSD 6al and blaster 2
fuel via laptop controlled megasquirt v2.2 www.megasquirt.org
Innovate wide band o2 sensor
Old May 8, 2009 | 04:56 PM
  #538
Sizzle Chest's Avatar
Hey all, here's my 81 SR5, all stock, check out that matching canopy! Very fun but considering selling it for a 4runner. Someone please talk me out of doing it! Sorry about the small pics, tried photobucket but didn't work for some reason.
Attached Thumbnails Hey  1st Gen Pickup Crowd! **83 & Earlier ONLY** (Post your Pics Please!)-truck-1.jpg   Hey  1st Gen Pickup Crowd! **83 & Earlier ONLY** (Post your Pics Please!)-truck-2.jpg   Hey  1st Gen Pickup Crowd! **83 & Earlier ONLY** (Post your Pics Please!)-another-outside.jpg
Old May 8, 2009 | 05:49 PM
  #539
AWESOME TRUCK! I absolutely love this color scheme, maybe one day I'll attempt it with my 79
Old May 8, 2009 | 06:08 PM
  #540
dropzone's Avatar
Fossilized
hmmm..that truck looks very familiar, like one I tried to buy from a friend at work...Says Siberia but the truck has Oregon Plates...having trouble getting it to pass DEQ?
