Pre 84 Trucks 1st gen pickups
Heater coolant valve?
Old Apr 29, 2013 | 07:50 AM
buckshot307's Avatar
Okay so if I'm right the heater core is heated by coolant from the radiator right? There's a valve that controls the flow of it on my 1980 Pickup that was connected to the heater control panel. Problem is I dont know if it actually works or not, and it is leaking coolant really bad. I was wondering what i could use to fix this? There is no compressor in my truck so I have no air but I dont care really. I could make it so that no matter what the heat is on but I'm not sure how this valve is supposed to work and what to put in its place.
Has anyone else had trouble with this or replaced theirs?
Old Apr 29, 2013 | 08:05 AM
aztoyman's Avatar
It allows coolant heated by the engine to circulate through the heater core. It is operated by a cable from your heater control. Open or closed.
You need to replace it with new or used if you want to have a heater. Or you can just eliminate the heater and lines.
Old Apr 29, 2013 | 12:15 PM
So can I just put a pipe in there so its always on heat? Or where would I find a replacement part?
Old Apr 29, 2013 | 02:03 PM
83's Avatar
83
Yeah somebody just bypassed mine. So there's always heat flowing through there. What you can do, is put an in-line shutoff valve in the side that brings coolant into the cab. Just turn the valve to closed when the weather gets warm.
You will feel the heat coming off the heater core all summer if you don't do that.
Or you can fix it back to original condition. I'd say dealership, maybe Rock Auto, or any auto parts store should have that stuff.
Old Apr 29, 2013 | 05:19 PM
pat24's Avatar
in my opinion do not just eliminate it entirely mine was stuck open last summer at first it was ok i didn't mind but when mid summer hit it was awful at least make a valve so you just have to open the hood to turn it on mind you i live in Maine so a really hot day is 90 and the last thing you want is the heat from the heater core on you when your trying to cool off with the windows down and if it raining out forget it nothing but hot air
Old Apr 29, 2013 | 05:40 PM
shlobeck's Avatar
Check ebay or your toyota dealer, i believe the part is still available. Geez I'd spend the time and money to get it right, it's not that tough to replace/install. good luck
Old Apr 29, 2013 | 05:49 PM
pat24's Avatar
ya it does take all of 2 min to replace i found my new one in a junk yard in very good shape
Old Jun 8, 2014 | 12:31 PM
trevorthetrekker's Avatar
I have this same valve which is leaking. Does anyone know of a part number for this valve? I have only been able to find used ones on ebay, hoping to get a new one. Has anyone tried to rebuild these?
Old Jun 8, 2014 | 12:39 PM
rworegon's Avatar
Is this it? 87240 which is P/N 82740-89111 http://www.toyomotorparts.com/Page_P...2140,2156,2159?
If I missed your rigs info, use the Change Vehicle link.
Old Jun 8, 2014 | 02:08 PM
That's it, thanks!
...too bad everybody wants $90 for it!
Blamalam
Mar 12, 2022 07:34 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
JaredL
Mar 28, 2016 09:08 PM
94 Newbie
Aug 6, 2015 10:33 AM
jjrbus
Jul 23, 2015 05:05 PM
