Pre 84 Trucks 1st gen pickups
Which grille emblem
Old Sep 26, 2020 | 10:05 AM
Groundpounder17's Avatar
Which grille emblem
I was needing to replace my headlights and fix the grille that the PO had held together with zip ties on my ‘82 pickup so I decided it’s a good time to switch from square to round headlamps. When I tried to switch my grille emblem over I realized it doesn’t fit. Can anyone tell and show me a pic of the correct one so I can try to find one?
What I’ve got
What I need
Old Sep 26, 2020 | 10:39 AM
swampedout's Avatar
5 Year Member
80 top
79 bottom
Old Sep 26, 2020 | 12:29 PM
Originally Posted by swampedout
80 top
79 bottom
they both look like mine just in different grilles. Are they smaller
Old Sep 26, 2020 | 01:26 PM
Another question. The PO had the grille held on by zip ties. I was looking at the Toyota parts diagram and it shows I need clips, part number 90467-13005. So how are these clips attached? Is there no screws used with these clips?
The bottom image in the diagram is my new grille.
This is the clips referenced on the diagram
This is one of the post on the grille that the clips supposedly attach to
Old Sep 26, 2020 | 02:40 PM
swampedout's Avatar
5 Year Member
The "T" logo in yours is more squat, shorter.
Ill measure and check clips this wknd. In the middle of a fence project
Old Oct 3, 2020 | 08:28 AM
swampedout's Avatar
5 Year Member
So the top 2 pics are of the outside mounting points, which use the clip you pictured above.
the next 2 are the inside brackets which has a similar clip but has a small screw going into the pin. These center clips with the screws seem to be holding the weight of the grille.
top and bottom mirror each other, center clip has a screw and outer pins dont, on both top n bottom.
Old Oct 3, 2020 | 08:32 AM
thanks
Old Oct 8, 2020 | 04:46 PM
I just got the right grille emblem off eBay. It needs cleaned up and painted
camo31_10.50
Oct 13, 2009 09:46 PM
Camach
16
Mar 21, 2009 12:27 PM
94yota05gto
Aug 18, 2008 01:14 PM
NMcruser
Oct 27, 2005 12:27 PM
butnut
19
Nov 30, 2003 05:37 PM
