Pre 84 Trucks 1st gen pickups
Fuse block interchange?
Old Aug 23, 2009 | 05:49 PM
81Hilux's Avatar
I'm trying to track down why my tail lights don't work, and I thought I'd start with the obvious, the fuse. It turns out that not only is the fuse missing, the contacts for the fuse are completely broken off. So, I'm off to the junkyard tomorrow to find a good fuse block.
Will any 1979-1983 Toyota truck fuse block work?
Old Aug 23, 2009 | 08:50 PM
slacker's Avatar
yep .. 79-83 2WD or 4WD
Old Aug 24, 2009 | 07:24 AM
81Hilux's Avatar
Cool, thanks for the help.
Old Aug 24, 2009 | 03:25 PM
81Hilux's Avatar
I just got back from the junkyard, the two 1983 trucks there both had fuse blocks set up for ATO/ATC blade style fuses. My 1981 has the AGC glass fuses, and a few less fuses than the 83s. I found a 1976 Corolla, but it only had 8 fuses. Oh well, I did find some pieces for my rear slider window, the little rubber bumpstops for the hood and some fasteners.
Old Aug 24, 2009 | 03:45 PM
slacker's Avatar
thats ok ... they are still interchangeable ..
If your going to replace the fuse block .. you have to pull the "pins" .. and they will just re-connect into the new "style" block ..
lots of work , but it can be done .
Nice you found some other pieces anyway
Old Aug 24, 2009 | 04:25 PM
81Hilux's Avatar
If I had $100 to spare, I think I would do this:
http://www.4wheelinjunkycomoffroadpr...jeep-14/Detail
Most of my wiring is hacked/trashed, so maybe I should.
Good to know about pulling the pins in the block. I was going to just cut the wires, and start splicing.
theking11863
Mar 19, 2016 09:36 PM
Gutted91
Aug 23, 2015 11:58 PM
izzmee
Aug 17, 2015 10:20 AM
Mrhoadley
Aug 4, 2015 06:08 PM
rushw
Jul 18, 2015 01:46 PM
