Pre 84 Trucks 1st gen pickups
Front Main!!!!!!!!!
Old Dec 23, 2007 | 02:05 PM
camo31_10.50's Avatar
Front Main!!!!!!!!!
ok im in the process of replacing the front main seal...it has been simple so far...got everything out...ok let me try to explain it..(bear with me)..i took the pulley off.(harmonic balancer (whatever))...behind that was a seal...(front main i thought)...then behind that...there is ANOTHER seal...what seal is that...and is it stealership item...they only listed the one front main that they gave me...the first seal that i took out is deeper or thicker than the one the dealership gave me....the second one looks to be the same size as the one i got from the dealership...ANY help will be GREATLY appreciated...
Ken,
Old Dec 23, 2007 | 02:59 PM
YotaJunky's Avatar
hmm... pics would be in order here. As far as I know, there's only one seal in the oil pump behind the harmonic balancer.
Old Dec 23, 2007 | 03:28 PM
i will be getting pics up later tonight..i didnt think about taking pics...lol
Old Dec 23, 2007 | 08:33 PM
81redbluffyota's Avatar
From: I live in Red Bluff ca. Right by the Sacramento river
Strange, I just did my Front seal, and didnt see this other seal. Behind the oil pump housing is a O ring, is this what you are referring to? Is this a 22r?
Old Dec 23, 2007 | 08:44 PM
no its RIGHT BEHIND THE FRONT MAIN SEAL!....like...u pop out the front main seal...then its RIGHT BEHIND IT!...my dad didnt take any pics of it while i was gone...pics will be up tomorrow.
Ken,
Old Dec 23, 2007 | 08:50 PM
toy power's Avatar
from what i have heard, some people will use two thinner seals when the balancer gets a groove worn into it; rather than just buying a sleeve. the idea is to get the lip of the seal to ride on a part of the balancer that is not worn. i would remove that second seal you see, and just use the stock part # seal.. with a sleeve on the balancer if you need it.
Old Dec 23, 2007 | 09:44 PM
Dont use a sleeve, those things blow, almost impossible to get em to stay round. Just meaure where the old seal was riding, and get a thicker or thinner seal. I think they came with 7mm, and I got a 10mm one to do mine, I dint need a thicker one, just got it in case. You just want it to ride on a different spot. Hope this helps.
Old Dec 24, 2007 | 02:01 PM
fredbauer's Avatar
Talking
Just did the one in my 81. Took out the factory 11mm one and replaced it with one out of a 95 22R only 7mm thick. Worked perfectly. Fred Merry Christmas
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
toyoda8488
Jul 5, 2015 10:18 PM
