FRONT driveshaft
FRONT driveshaft
what front driveshafts can i run for my '80..does it have to be from a solid axle truck...or can i run one from a IFS rig...i need a new front driveshaft...and i know of a truck around town...its junk sittin in a yard on blocks....and i cant ever see if its IFS or SA...so i need to know if i can run an IFS driveshaft up front..thanks
You can modify an IFS shaft for more travel:
http://www.4x4wire.com/toyota/tech/cvmod/
Likely your '80 will have the smaller bolts and different flange bolt pattern, so if you don't want to mess with changing that around, stick with something of the same vintage as your truck. Try http://www.car-part.com/ or check with a local driveline shop and see if your's can be rebuilt or fix whatever is wrong with yours. Or make a square tube shaft with a pair of u-joints if you need something cheap:
- http://simbur.com/toyota4runner/drive_shafts.htm
Not yet. I just made it a couple weeks ago. I need to get the pics I took of it on my computer.
Im wondering how much grease fittings are gonna help. I would think as tight as it is the grease isnt going to go very far and the inner shaft goes all the way up the outer except for about 2". I know id have to at least put 4 zerks but im thinking that wont be enough. And the shaft has a groove cut into it all along one side to allow for the weld seam of the outer shaft.
How many and where are the ones you're talking about?
yea i have thought about a square shaft...but..im not exactly sure on how to make one...and how long to make it..if someone could give me the specs on one for a STOCK 1st gen pickup without the swaybar...then i will just do that...seems to be the better route anyway
P.S. wont that thing vibrate like som b!tch while im in 4wheel drive and muddin
...i mean..we like to throw mud everywhere...i just dont want it to vibrate things loose...
i need a new front shaft because mine got sheared in half (see the thread SCREWED and TATTOOED) and my replacement that was supposed to be good(thanks a lot redvetter
) is actually junk..and the driveline shop said it would be somewhere around $300 total to get everything right...
weeellllll i found an ifs shaft out of a 86 TURBO 4x4....(the turbo'd 22re was NOT in it...damnit..i was SOOOO excited when i seen it too..until he popped the hood and a regular 22r was under there) would i be able to take the yolk out of that shaft...and put it in my SA shaft....this is the part i need
hopefully those pics arent HUGE!...now this part IS off of a 3/4 dodge 4x4....but its what i need for my truck...thanks for the info
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
coffey50
Jul 28, 2015 10:55 AM
kirkrunner
Jul 27, 2015 07:59 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
