Pre 84 Trucks 1st gen pickups
Front Axle/Hub rebuild question
Old Aug 25, 2019 | 03:56 PM
cascades's Avatar
5 Year Member
I am in the process of doing a front axle rebuild and have a question regarding the inner hub shaft where the dust seal rides. I have some substantial grooves worn in the shaft. See picture. Is there an appropriate sleeve that will fit? Should I just roll with it and hope for the best? Other options?
Old Aug 26, 2019 | 05:36 AM
millball's Avatar
There might be a redi-sleeve to fit that, IDK?
The real sealing is done by the inside seal.
If it was mine I'd put new dust seals on if the old ones were brittle, or damaged, clean that up with a little emery cloth, and Roll.
Old Aug 26, 2019 | 05:58 AM
cascades's Avatar
5 Year Member
Thanks millball. I'm leaning towards just going with it. I've got all new seals and bearings from Marlin, so will definitely replace the old one. It was all dried up.
Marley2984
Jul 28, 2017 04:13 PM
Mr. Spooky
Apr 25, 2013 04:16 PM
C17loadclear
Feb 10, 2013 08:11 AM
bwhite
Apr 24, 2007 01:39 PM
