Pre 84 Trucks 1st gen pickups
Clutch...
Old Jan 12, 2018 | 12:37 PM
KingSirBrummie's Avatar
Clutch...
Hey there, just noticed this ooze from my clutch.. clutch fluid still full and clear in the reservoir.. any ideas? Maybe assembly grease. . ?
Old Jan 12, 2018 | 01:00 PM
95yoda's Avatar
Looks like old grease
Old Jan 28, 2018 | 05:36 PM
goofybud16's Avatar
Looks like a leaky master cylinder to me. I'd say clean it off, and if it keeps leaking, replace or rebuild the clutch master cylinder. I'd inspect the slave too if it hasn't been recently replaced.
Old Jan 29, 2018 | 06:21 AM
83's Avatar
83
It would make sense, because of the location of the cylinder, but that sure doesn't look like brake fluid to me.
Old Jan 31, 2018 | 01:50 PM
goofybud16's Avatar
While I do agree, it doesn't look like it, it could have just started picking up any dirt/contaminants in the cylinder.
If it keeps leaking, what could it be other than brake fluid? Unless I'm mistaken, there isn't much in a clutch cylinder as far as liquids other than brake fluid.
Also, what color is the fluid that comes out of the slave when you bleed it? Just because the reservoir is clean doesn't mean the rest of the system necessarily is.
Old Jan 31, 2018 | 03:22 PM
83's Avatar
83
Yeah, I agree.
I think it's possible somebody greased the piston at some point. You just never know what a PO might have done...
Either way, worth looking into the possibility of brake fluid leaking and picking up gunk on the way.
What's it feel like?
Old Feb 4, 2018 | 08:07 PM
rowdy235's Avatar
Always possible brake fluid picked up contaminants/rust/dirt/etc. along the way. As far as what it could be, brake fluid is the only fluid around that area. Could be grease or penetrating oil from a prior repair.
If it were me (provided the clutch was working properly), I'd wipe it off and keep an eye on it. If it keeps coming back, look into replacing the master/slave.
Old Feb 5, 2018 | 05:24 PM
WolfMann's Avatar
What's it smell like? Has it returned since wiping it off?
Old Feb 6, 2018 | 04:06 AM
Melrose 4r's Avatar
5 Year Member
Wipe it off, monitor it, it will leak for years and all over the carpet if it's a bad leak. Even then you can continue to drive until you have time to replace the clutch master and slave as long as you don't allow the fluid to run out in the master. Not many of our trucks still have the original clutch master and slave. It's a very common repair.
Old Feb 7, 2018 | 06:17 AM
83's Avatar
83
Brake fluid is also very corrosive. I wouldn't want it leaking down my firewall onto the floorboards...
It won't feel like oil or grease if you feel it.
Old Feb 8, 2018 | 08:13 AM
rickc5's Avatar
All of a sudden I'm interested in this thread cuz I noticed this morning that my clutch master cylinder is leaking.
One more thing to add to the (never ending) to-do list.
geoduke
Apr 4, 2006 06:51 PM
p.m.coupe
Mar 4, 2006 01:18 PM
YotaJunky
Nov 21, 2005 07:03 PM
bflooks
Jun 14, 2005 06:31 PM
sunflower
May 8, 2005 12:57 AM
