Cam and Carb questions
when i first fgot my 80 2wd i chased my tail on vac leaks. fixed and replaced all kinds of stuff. got out the carb clean to go hunting again and found that the throttle shaft had egg shaped the pivot hole in the body (HUGE VACUUM LEAK). I found another aisin to replave it for something like $20 from a buddy and went through it myself. bolted it on and i will be comletely honest, it ran great. but about 4 months later my idle progressively started creeping up. did more vac leak hunting and bamski, the throttle shaft again. said to hell with the aisins and went weber, haven't had a problem in 2.5 years. just my personal experience. no need to get snotty
priest16
15
Aug 6, 2015 07:43 AM
cgilley
Jul 25, 2015 10:55 PM
i've taken up any slack in it...but it's by no means tight.
