Pre 84 Trucks 1st gen pickups
Bright Bue Lash
Old Oct 14, 2006 | 07:33 PM
Mista_shrpnl's Avatar
Bright Bue Lash
Ok, so after alooong day of wheelin and finally killin my runner( see other thread) I jump in my 79 2WD to go and run to the parts house..
About a block down the road I have a big blue flash from under my front end..followed by nothing..no lights anywhere, and more importantly, no spark/ignition...
Whats this sound like to you guys...blown fusible link? and if so, where do I find it at?
ANY help is great! Im back to walking...
Old Oct 14, 2006 | 07:42 PM
Elton's Avatar
dont know sounds pretty scary
Old Oct 14, 2006 | 07:45 PM
it sure wasnt very settling...to say the least its been a rough day for me and the Toy's.
Old Oct 14, 2006 | 07:51 PM
Elton's Avatar
i guess both trucks in one day .... have you checked the fuse's on both trucks ?
Old Oct 16, 2006 | 07:17 AM
Runners back for the most part..Pickup still not good. All fuses are good...anyone?
Old Oct 16, 2006 | 09:01 AM
Cebby's Avatar
Positive battery cable either came off or touched the hood and was arcing/welding itself, killing the battery cells. Just a guess...
Old Oct 16, 2006 | 10:19 AM
MNBOY's Avatar
Mike beat me to it. I've forgotten to secure the battery and had it hit the hood and short out, Kinda like what you described. Check ground wires to body in the engine compartment, one is probably gone or very crispy.
Either that or it's just an Everett, WA thing.
Old Oct 16, 2006 | 10:36 AM
Ok, Ill double check that..what perplexes me is that Im still getting the Red indicater lights in the dash (key on) Just not lights, ignition, or starter...
Back to under the truck I go!
Thanks!
Old Nov 13, 2006 | 11:13 AM
4XTOYOTAX4's Avatar
My truck had the light indicator no starter problem, it turned out to be the ground. I ended up grounding the batt to the engine block and the fender as well as grounding the engine to the frame and cab. This seems to be especially important for trucks that see a lot of mud.
foampile
Dec 18, 2022 01:29 PM
PBRaddict#1
Sep 22, 2015 07:50 AM
dropzone
Sep 13, 2015 11:18 AM
Streetrod19772000
Sep 10, 2015 06:22 PM
TDonkey
Jul 26, 2015 10:14 AM
