Pre 84 Trucks 1st gen pickups
Body lift results in carb linkage misalignment
Old 11-21-2014, 09:39 PM
timberwolf400's Avatar
I put a 2" body lift on my 1980 2wd sr5. I think I've got all the extension and alignment issues covered with the exception of the carb linkage. The linkage assembly is mounted to the firewall. Since the engine stayed on the frame in the original position the body lift resulted in the linkage being 2" higher than the rear of the carb where it connects. Looks like the two obvious options are either raise the carb or lower the linkage. The firewall has a pretty irregular shape and the linkage mount conforms. Lowering the linkage makes a shimmed together mess. Raising the carb means two inches of spacers between the manifold and carb base plus longer mounting studs. The concern I would there is vacuum leaks and carb performance. What's the best way to go here? Thanks
Old 11-22-2014, 07:22 AM
gillesdetrail's Avatar
If you have a weber carb, you can use a transdapt adapter, which I run. It raises the carb 2 inches higher, you only have one plate (the spacer), two gaskets and it's a quality piece unlike the redline adapters which always seem to leak for 99% of the people. If installed and torqued properly you will not have leaks with the transdapt, plus it's around 40$.
Old 11-23-2014, 07:30 PM
Staff
kawazx636's Avatar
Or you could get a linkage setup that mounts to the valve cover. I'm not quite sure why they mounted the linkage to the firewall on some years - that never made much sense to me.
Old 11-26-2014, 07:54 AM
KCsNATION's Avatar
i just did this 2 days ago let me get some pics for you
Old 11-26-2014, 07:56 AM
KCsNATION's Avatar
most of the linkages that are on the fire wall have cruise control
Old 11-26-2014, 07:59 AM
KCsNATION's Avatar
what you need is to build some relocation brackets really its just 2-3 step offs from different bolts lower on the fire wall
Flying91
45
04-11-2024 04:39 PM
kazuya2416
04-05-2024 02:17 AM
09-04-2015 09:27 AM
Cabell
07-24-2015 12:14 PM
Quick Reply: Body lift results in carb linkage misalignment
