Pre 84 Trucks 1st gen pickups
Automatic in my 1979 4x4?
Old Dec 15, 2010 | 01:18 PM
yotaman90's Avatar
Originally Posted by xxxtreme22r
If I am not wrong, there is a reason why Toyota did not mate the autos behind the turbo motors.
Dude, turbo 4runners are only automatic. Apparently they do sap a lot of power though......
Old Dec 15, 2010 | 01:53 PM
redneckcustoms13's Avatar
+1, made trucks also.
http://www.pirate4x4.com/forum/showthread.php?t=821008
Old Dec 15, 2010 | 02:18 PM
xxxtreme22r's Avatar
DOH !!! oh well haha thought I might have been wrong.
A340F 1984-1999 22RE, 22RTE
Old Dec 15, 2010 | 02:34 PM
R.DesJardin's Avatar
Swap
It's cool you pony up to the possibility you may have been wrong. So then let me know when you need swap info so you can ahave a strong trans.
Old Dec 15, 2010 | 02:41 PM
  #25
haha no thanks, I'll stick with my manual. If I sawp anything it will be to a R151F. But haven't figured out if it has the same 3rd and 4th gear ratios. To me, mine is too far apart.
Old Dec 15, 2010 | 02:44 PM
  #26
Toyota_tony_14's Avatar
Trannys?
Hey i was told that 22r and 22re trannys and tcases fit the v6 3.0
I thought they were bull shi&&ing me so i figured i would ask the pros
Old Dec 15, 2010 | 04:18 PM
  #27
If I am not wrong again (if I am someone tell me) but trannys and transfer cases do bell housings don't. Only thing I am not sure on is if you have to watch out for top verses forward shift transfer cases.
Old Dec 15, 2010 | 05:04 PM
  #28
peow130's Avatar
Originally Posted by Swimmerboy2112
You're going to need a new transfer case too i believe.
he won't.
regardless of top shift or forward shift, the main difference is length. a forward shift transmission has the shifter in the same position (in cab) as a top shift.
Old Dec 15, 2010 | 06:00 PM
  #29
t-cases
T cases are interchangable as far as bolting up, spline count of the input shaft is where you might find an issue and top shift and forward shift are of course variations. Check this out for a little bit of info. http://board.marlincrawler.com/index.php?topic=75938.0
Old Dec 15, 2010 | 06:06 PM
  #30
looks like I might be wrong. about the t-case then too. grr, not having a good day today lol.
Looks like the only one that is different was the one behind the 86-87 turbo trans.
all others are 21 spline in and 27 spline out.
Old Dec 15, 2010 | 06:27 PM
  #31
Don't look at it as being wrong look at it as an opportunity to learn something new.
Old Dec 15, 2010 | 06:39 PM
  #32
so does that mean if your swapping to say an R151F you have to swap the t-case too?
Old Dec 15, 2010 | 07:00 PM
  #33
Swaps
The real issue arises when swapping from a trans with a chain drive case to a gear drive case. So if your trans came with a gear drive case the swap is much simpler to keep the desired gear drive case. An adapter is required to go from a trans that had a chain drive case to a gear drive case. I'm sure I've forgot some variation or details, as I often do.
Old Dec 23, 2010 | 08:42 PM
  #34
truckman1966's Avatar
I'm all about innovation. and the only reason the toyota autos got such a bad rap was because they wer neglected and people wondered why their 200K mile A340 with the original fluid died on them. well duh! that's more than a TH350, C4, 904...... etc. So do the auto swap and tell us how it goes! AND FOR GOD'S SAKE, build a skidplate for the damn thing! you don't want any rocks coming up to say hi to your valve body.
Old Dec 23, 2010 | 09:11 PM
  #35
peow130's Avatar
No.
Just the flanges if you dont feel like drilling out new holes.
No truckman.. Like all auto's, there is a SERIOUS amount of torque loss. (unless you have a shiftkit like in a TH350 or TH400). Plus, the autos have a STUPID overdrive. Like .75 or something like that. Absolutely ridiculous..
Now, put a torque stealer behind an engine with only 110 FT. Lb's, well, it'll feel more like 35.
Tykiller1994
Aug 10, 2015 07:49 PM
vanion2
Jul 29, 2015 06:17 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
msane99
Jul 11, 2015 08:08 PM
madxman21
Jul 9, 2015 10:26 AM
